McIntosh here (cue cricket sounds)
LOL! The DartZeel NHB-458 Monoblocks!
In all seriousness though, my choice is the DartZeel NHB-108 (unless of course, you can really afford the 458 mono blocks!).
I miss my MC601's paired with a Conrad Johnson ET5 (at the time). I just did not appreciate what I had. Very musical and easy to listen to for hours on end.
Bless you Joe..
when conrad johnson tried to make a SS amp the first time, they failed. anyone remember the motif? the preamps were noisy and even had an underlying 'tube rush' or hiss and the amps possessed the worst kind of 'mosfet mist' like a veil over the music, the antithesis of transparent.
with modern gear, me thinks electrocompaniet, rowland, ayre and gamut would make the tube-like list. some class d amps ive heard come close.
Three amps interestingly missing from the list:
Technical Brain
Soulution
BALabo
technical brian showed at the newport show last month. i never heard of them before and it was a good sounding room, at the time i thought the TAD CR-1s had much to do with it.
Technical Brain
Soulution
BALabo
For those of you curious about my experiences with Pass, the amps we something XAand cost $16K or so. They drove the newer $50K Focals
