Gary, you mentioned Dumping Factor in your above post.
And I know for a fact that some speakers (more than others) luv a high 'dump' factor from the amps; what is your take please? ...On having tighter control over the drivers. ...Push-pull-stop.
The 911 has one of the highest damping factors of any amp available which is why I was personally first drawn to it. It's hard to top in terms of bass performance.
Although Burmester specifications are not easy to find, I could see it in the page of a dealer - a damping factor of 2750. Do you use cryogenic cooled superconductor cables to connect it to your speakers?Otherwise you risk degrading the damping factor of your system!
Soooo, Damping Factor is not much of a factor at the end? Or is it with certain speaker designs?
It is a factor, just that between 1,000 and 2,000 the sonic difference is much, much, less than between 10 and 20. I dare say that once the damping factor is beyond 100 or so, it makes minimal difference.
When I was developing the tube amps, getting the damping factor above 5 made the greatest difference.... and output impedance can very easily be adjusted using feedback. The greater the feedback, the higher the damping factor.
Thf99,
I am soooooo glad you are very happy with the amps. What transformer are you using? I'd love to get a hold of the dealer cables you are using. What brand/type cable is he using to make them. It sounds as if he knows what he is doing.
Just another interesting story.
Uncle Richard, a long time family friend in his 70s, came by this morning and he sat in his usual place in my living room. My system was on and after a short while, he fell asleep. When he woke up some 20 minutes later, he commented that the music was so relaxing and soothing that he fell asleep. He's never done this before! He said I should've gotten these amps a long time ago!
Again, that's why a demo in YOUR system is so important. I share your enthusiasm for Burmester, but I've heard that combination and it's way too forward sounding for my taste. That doesn't mean your choice is bad or wrong. Everyone perceives sound differently, and while we can argue forever about what's best, it really comes down to what you enjoy at the end of the day. If Odin makes you happy that's the choice you should go with.
So, Gary, based on your experience and taking the damping factor into consideration, which might be better for the 911s, mono or vertical biamping?
Exactly,
I am not a fan of silver cables but I confess I have not heard them all or the best. I am not a fan of bright or forward sound and need to look for great copper based cables. My preference for sound seems to mirror Jeff (Tonepub). It will be a while, but I will eventually like to try cables other than my Transparent Supers for my system.
The burmesters certainly are very cable sensitive. When I use silver cables, they seem to be on the bright side and quite unlistenable. They sound very brittle, if I may use the word. When I replace the silver cables with the copper cables made by my dealer, the whole soundscape was totally transformed! All of a sudden, my CDs just sound so good that they give me the goosebumps. For those of you who are still considering to acquire these beauties, do so! You won't regret it.
When you've got them, make sure you get a transformer (preferably 8 kva) with voltage control. This is very important in areas with voltage surges. When operating under a constant voltage (the voltage setting in the amps), there is another jump in performance. I've tested this many times (with and without the transformer) and the difference is huge.
With your Transparent the damping factor of 911's will be killed.
+1 Absolutely right.
I am not sure what you both mean "killed". Can you explain? I assume you do not recommend Transparent Super audio cables?
Also, will one 948 handle both mono amps?
