what's the advantage of the butterfly record and repro heads for Studer A810 ? Better recordings and playback ? I'm considering buying a complete headblock w/ butterfly heads if it's worth it. TIA
for A810, I don't know, but for a modified A80, the butterfly is much better
tony ma
maybe in a tube no feed back modification will in a different result
tony ma
From a recent conversation with Paul Weitzel:
"I have around 300 master dubs, all recorded on various decks. Some studios used Saki heads. Some used Taber. some used Nortronics professional grade. Some used wide tape head gaps, some used narrow. Some used high impedence heads, some used low impedence. My 3M and Scully decks are modified and with Paul's custom electronics, I feel that I can retrieve much more information than I can from my Studer decks (also modified) as an example. The key to getting as much as possible is to use a playback head with as similar characteristics as the record head that they had used. so I have 23 different headstack mounts for my Scully 280's, with different characteristics, so I can retrieve as much information as possible.."
i wish the master tapes we get in here had that much information. I'd just love to have tones!!!
Basically, you have to match the 3 or 4 characteristics of the record head as possible. It is a new concept for most guys, ... Even the professionals. I can't tell you how many times I've mentioned this to several of the guys who do this for a living. Most seem to think that they can purchase one new head and it will work for every master they play. I guess they never put much thought into it.
And the same headstack, without ever considering that they needed to match the characteristics of the record head. Paul mentioned this to the folks at Skywalker in the early/mid 1990's, and if you look at their masters, they made a notation on their master notes as to the impedence/gap width/ headstack material (copper, iron, etc.) , of the record head used. This way, when they play it back, they don't have to try 20 plus some headstacks to try to get the correct sound from the playback."
I certainly understand the need to match the gap, and to a lesser degree the material, but the impedance? I can't see how that has any bearing on the playback except for being correct to the input of the playback preamp.From a recent conversation with Paul Weitzel:
We have modified A80 machines and can swap heads pretty quickly. I've done tape transfers for 100's of clients and they always choose the NAB heads over the DIN heads.
Based on what criteria, Bruce? By listening comparisons, or explanation?We have modified A80 machines and can swap heads pretty quickly. I've done tape transfers for 100's of clients and they always choose the NAB heads over the DIN heads.
What do you hear in listening comparisons? (other than level)
--Bill
