Installed over the weekend, and now waiting for your sonic observationsA request for XDMS beta install was sent to install to taiko support emal - Ticket 4109. Can't wait to start evaluating the new beta!
Ed's the bestWOW, I’ve got to give a shout out and a big thank you to everyone at Taiko Audio. I just submitted my request for XDMS yesterday and Ed is currently downloading it. Taiko customer support is amazing…….
Ed is great. I hold the record for slowest scan speed on the XDMS install, currently at 12 hours. He tested my internet speed and it was at 490mb. So their cloud server must be slow…..Ed's the best![]()
I tried it in the open USB port in my NAS with negative results. I'm on Olympus, so nothing goes in its (or the router's) USB unless that's how you chose to connect to the DAC. I put Furutech XLR terminators in the preamp with marginal positive impact to my ears. Others have more sensitive hearing.Just installed the Furutech NCF Clear Line USB isolator in the default DAC output USB output. It’s too soon to tell if it achieves my goal or reducing background noise as it needs time to settle. So far, it doesn’t seem to be harming the sound, and perhaps making it slightly more ‘natural’ and with a bit more clarity. The voice separation in Lonestar, when Norah is singing with the chorus is more pronounced, in a very good way: it now sounds more convincingly like 3 vocalists. Nice! There also seems to be a bit better alignment of instruments to vocalists in terms of placement in the room.
NCF Clear Line-USB - Furutech
furutech.com
Thanks if I remember Emile's post correctly, a device in any USB port in the Olympus or router will add noise.It’s not in the signal path so you can try it in the Olympus USB, unless it’s physically not connected to anything. It seems to be a small EMI filter that also cleans up the 5V USB voltage. It could be at the expense of the ‘airiness’ of the highs; which is always a potential drawback when you add filtering.
I’ll continue to evaluate mine after a few days, then unplug and listen without. If the initial impressions were correct: more clarity and improved sound space e,g., by better vocal separation and placement, it may be worth it even if there is some loss of airiness. It becomes a way to fine-tune the sound to your room/equipment/preferences.. Especially for ~$250 it’s worth a try.
No, I didnt post about a static IP being better than a DNS assigned one. I was explaining to someone who was asking how to make an IP static because their NAS IP kept on switching addresses and it was inconvenient. As for not trying it, it's not about being close minded. It's work to get behind the Olympus, I trust Emile, and Ive been routinely disappointed by these types of products when I used them elsewhere. However, I might try it in the future. I'll just need half an hour an a lot of band aids.I’m sure Emile has not tried everything, with all possible equipment configurations. If you have it, why not try it? Aren’t you also posting about how a static vs dynamic IP has improved A/V quality on your ATVX? Why be close-minded when it comes to this but not when it comes to a static IP having any benefit (which I don’t understand)…
This is not an attack at all, please don’t take it that way.
Just my 2 cents that we should all continue to be open-minded, because anything can make a difference…
