Di-fi, i agree with you. I actually test the S1 Evo and N1 switch, and first of all Edgerouter X SFP Is difficult to find in France, and lastly I am not ready to face a tricky configuration! By the way, what about a simple optical bridge as a Gustard N18 switch, by example?
When it comes to achieving the best sound quality, it’s important to remember that a switch and a router don’t do the same thing —
at all. In my opinion, many audiophiles overlook the router’s critical role in
preventing noise (from traffic, PSUs, and other network devices) from ever reaching the final switch, streamer, or DAC.
I think in audio we ideally want a
separate audio network — whether that’s physical, virtual (like using a VPN), or a combination of both. (One of) the audio router’s role is to block off the rest of the home network, isolating the audio chain. The switch, on the other hand, can only forward or distribute traffic; it doesn’t isolate noise or segment the network on its own.
In the end, it’s all about making sure the DAC receives the
cleanest, quietest signal possible. That said, whether you can actually
hear the difference does depend on your specific system and network setup.
If Marcin can help set you up, here you go:
Edgerouter X SFP
Ubiquiti Networks ER-X-SFP : Amazon.fr: Computers
www.amazon.fr
(you pay a premium, but it seems available).
Do take note of this, you also have to buy a pair of the recommended SFP optical transceivers:
Fiber from the EdgeRouter X SFP with Finisar FTLX1475D3BTL (hands down the best sounding SFP modules) goes to the SFP port in the XACT N1 — also fitted with the same Finisar module.
A good second choice : FTLF1318P3BTL
And single-mode optical fiber cable with LC to LC connection. (A yellow cable with blue connectors).
Bonne chance!
PS. Did I say how lucky you are you can audition N1 + S1? Enjoy, and I hope you will be tempted to keep both!
