Taiko Audio is not participating in an official capacity, nor have we organized anything for the show. Instead, we maintain focus on the production of Olympus products and getting these delivered to our customers as soon as possible.May we know totally how many Olympus will be at Munich Show and in which rooms?
Thanks!
Contacted support and sent requested info to Christiaan...I'm not sure what that indicates. We have someone in the team who is not on WBF but is an expert in this field. Can you contact us via support@taikoaudio.com so we can troubleshoot?
Well, Roon is looking to update, yet again. This time its Roon 2.51, build 1534 (I'm presently on 2.50, build 1528). Any takers yet? Is it safe?
Thanks for the reassuring report. I've got ~1,200 hours on the analog card in an Olympus + I/O and I can understand the SQ uplift ride you're experiencing. Better every day, and for some time!I upgraded yesterday and found a huge uptick in sound quality. However, I am also breaking in the analog DAC card so this was far from a controlled experiment. However, if the upgrade sucked I don’t think I would be hearing what I am.
For the best heat dissipation, it's best to stack the server on top of the I/O. This is how they are designed.@Emile
Can the IO be stacked on top of the Olympus?
Heat dissipation and damping are my two immediate thoughts.
Why?
Future upgrades will need access to IO and this cowboy ain't pitching bails of hay no more.
Eventually, an upgrade to support will separate boxes.. For now, and for the next year, I'm limited.
Marc
@Taiko Audio Emile, is the SQ of a hard drive plugged into the Extreme Router's USB port the same as or very similar to the SQ of a NAS (used in tandem with the Router)? It would be great if we don't need to invest in or use a NAS.Hi @Armsan ,
We completed this update some time ago.
However, since launching it will undoubtedly require substantial initial support, we’ve decided to postpone the launch—alongside several other updates and releases.
Our top priority, and where we must focus our full effort, is serving those who are still waiting for their Olympus.
I am not Emile but maybe this recent post by Taiko hints in a certain direction?@Taiko Audio Emile, is the SQ of a hard drive plugged into the Extreme Router's USB port the same as or very similar to the SQ of a NAS (used in tandem with the Router)? It would be great if we don't need to invest in or use a NAS.
File transfer from local drives is inferior to TCP/IP transfer on the Olympus when combined with the router.
May I ask what preamp you are using?A while back before I received my Olympus @Taiko Audio was asking for feedback about the output level of the XDMI DAC card. I don’t know what the actual voltage output is but I think it is a little low. When I played my Horizon (via XDMI) my preamp was set to 10-12 or so which is about halfway open. With the DAC card it is closer to 23-24 which is getting close to the max output level. If I had my choice I would like to see the output increased a bit.
Not here. With a VAC Master Pre, the volume knob is normally set at 9-10 o’clock. 11 o’clock with classical music.A while back before I received my Olympus @Taiko Audio was asking for feedback about the output level of the XDMI DAC card. I don’t know what the actual voltage output is but I think it is a little low. When I played my Horizon (via XDMI) my preamp was set to 10-12 or so which is about halfway open. With the DAC card it is closer to 23-24 which is getting close to the max output level. If I had my choice I would like to see the output increased a bit.
My Areis Cerat Ageto has 26 steps. I’m typically set between 12 and 15 which seems to be a comfortable place.Not here. With a VAC Master Pre, the volume knob is normally set at 9-10 o’clock. 11 o’clock with classical music.
Curious, I remember awhile back you mentioning you couldn't run the H at 63. Did you find when running XDMI with the H you could bump the volume higher on the H?A while back before I received my Olympus @Taiko Audio was asking for feedback about the output level of the XDMI DAC card. I don’t know what the actual voltage output is but I think it is a little low. When I played my Horizon (via XDMI) my preamp was set to 10-12 or so which is about halfway open. With the DAC card it is closer to 23-24 which is getting close to the max output level. If I had my choice I would like to see the output increased a bit.
