Just to be sure. So the grounding post next to the ac is chassis ground but not regular home ground post. Thanks
Roon 1525..sounds amazing
Finally a good update
For clarity, I always reboot after a Roon update so I can't comment on sonics before the rebootInteresting, I just did the upgrade.
Directly after the upgrade it did actually sound a bit worse here! After a reboot of the Olympus it sounds the same as before again though. So I’m a bit in the dark here.
We have developed a few “dials” we can adjust to rebalance things if anything drastic changes in Roon, but I’ve not yet come across a scenario where this was necessary (we can actually make these available in the future as part of a BMS app extension we’re working on).
An exception is that sometimes Roon enables a debug mode for a period of time, with verbose logging enabled, to find a solution to a more persistent problem they’re encountering. Like for example the playback queue interruptions (which appear to be largely gone now, in fact completely for me). If they do this there’s an audible impact we cannot compensate for, as this usually goes accompanied by an increase in disk activity, which we only have one option for to “immunise” the system for, being the I/O.
Give it a few minutesIs there something in the Reboot process I don't understand?
I upgraded Roon, pressed and held the front underside button until the middle light went off, and then pressed and released that button. Middle light came back on (and heard a faint click).
But now Roon "can't find server."
Try closing the remote instance of Roon (swipe up). Re-open. Or reboot your ipad, then open remote Roon.Is there something in the Reboot process I don't understand?
It won’t hurt to try thatTried all of the above, including Re
boots a couple of times. Should I completely power down and restart the server?
Suggest:Tried all of the above, including Re
Good to know! Thanks. I'll update Roon when I get home as I've been avoiding those without hearing whether it actually degrades the sound. BDT Cascade upgrade is sounding fantastic on the Olympus BTW.Roon 1525..sounds amazing
I should’ve mentioned this is for the Olympus serverSuggest:
1. Restart the T router
2. Front O button as follows... a quick push of the front button. Look inside (on top) for 00 on the rear left.
3. A quick push of front O button and wait a minute...
It is.I should’ve mentioned this is for the Olympus server
My ipad shows Build 1516...out of curiosity, my MacBook Pro has build 1525 as does the Olympus but my iPad shows version 2.0 build 1496...is that the current version for the iPad
How do I update my iPad as it does not show as an update available?My ipad shows Build 1516...
