Add a new test line
[S+] Price>=8xk
16. David Laboga Ethernet-Ruby
Full, fleshy, soft and warm, good 3D sound field, strong tension, enthusiastic and energetic, excellent musicality,
The low frequency is shocking and authoritative, with excellent elasticity, relaxed and fascinating, without deliberately strengthening the extension and details.
If we only talk about low frequency, the DL RUBY of these tested cables should be the closest to my ideal appearance
If you feel that the system is too bright, too stimulating, too cold, and too acoustic, David Laboga is a very good choice.
Pick a few S-grade cables and the image in your mind after listening to them for the first time
A.Crystal Cable Da Vinci
B.Vertere Acoustics Pulse-HB
C.David Laboga Ethernet-Ruby
D.Shunyata Sigma X
[S+] Price>=8xk
D.Shunyata Sigma X
[A+]
9. Network Acoustics Muon Pro
Balanced, smooth, thick, low-key, neutral, no taint to advantages and disadvantages
Use Muon Pro filter to get a bonus effect, you can put it anywhere
[A+]
10. Final Touch Audio Metis
Precise positioning and layering, small details and weak sounds are also enhanced, and the sense of air flow
The overall auditory picture is richer. The appeal is good. The precise positioning is particularly enjoyable when listening to EDM.
[S-]
11.Audience hidden treasure
Smooth, clean, transparent, delicate, natural, clear, the texture of the instrument is excellent
The harmony between multiple instruments is intoxicating, and the best choice for musicality
[S-]
12.Brise Audio YATONO-LAN
Beautiful and round, good sense of space, excellent overtones, good separation and beautiful texture,
Good atmosphere, slightly increased thickness and warmth, sweet vocals, vigorous and powerful low frequencies
PS: The line is very tough and difficult to bend
S
13. Shunyata Sigma X
Low-pitched, pure, stable, leisurely and calm. Wide sound field.
Very neutral, clear vocals with a sense of overall picture. Slow songs are highly toxic.
The details and textures of musical instruments are particularly realistic and fascinating. The low-frequency punch is excellent.
In addition, this one has some of the effects of muon pro filter, and it can reduce noise much more obviously when used alone than other ones.
[S?]
14. Crystal Cable Da Vinci
Crystal clear, realistic, extremely high resolution, strong sense of energy, strong sense of punch. The overall brightness of the picture is improved
The overall tone rises slightly by half a key, and sparkling little stars are scattered at the corners of the notes at any time.
The overall quality should be the highest in this test line, and the personality is the strongest. The fierce horse needs a good saddle.
Artists don't care what you think, they only care what I think.
[S+]
15.Vertere Acoustics Pulse-HB
Real, smart, clean and clear overtones and delicate extension, three-frequency layering
The continuity control is excellent, the musicality and sound quality are equally important, the mid-high frequency has a lot of gloss and moisture,
The low frequency reduces the sense of oppression and creates a more three-dimensional spatial reverberation.
I often forget that I am testing. Vertere's digital line is really top-notch (for me).
