No problem, my Center Stage2 1.5 has a diameter of 38 mm and if I were to upgrade to the Ultra TT in the future, These have a diameter of 2", approximately 51 mm.
Thx Vassil
Thx Vassil
I use Center Stage Ultra LS 2.25 and there are no issues
Reactions: nonesup
I see. However, what I'm trying to do is have my Center Stages replace the factory feet, since according to Emile, it's the only way to ensure no damage is caused to the Olympus, which is very heavy.
Reactions: Steve Williams
I agree. Mine are situated in safe spots as determined by Christoph (tsaett) when he visited shortly after I received my O/IO (you can see where mine are placed if you enlarge the photo above) BTW I use Ultra TT under all other components....I had Ultra TT under my Extreme but with the weight of the O/IO combination I went with the Ultra LS 2.25. The sonic improvement was quite dramatic
Steve, what was your reason for looking for an alternative location, perhaps Joe from Critical Mass told you that it was better there than the factory feet?
I wasn’t anxious to remove the stock feet. Initially I did have one rear foot in the wrong location which did interfere with the XDMI board. Plus Emile hadn’t posted his admonitions yet so I guess some trial and error on my part. Plus the great weight of the two components when stacked prompted me to use the much sturdier LS Ultra 2.25 foot which I had switched to previously under my Extreme showed a better sonic gain than did the Ultra TT. If I had to do it again I would take Emile’s advice
Reactions: Taiko Audio
Thx
Dear Emile and Steve and nonesup and all other users of O+I/O,
A follow-up question of the discussion above for your advice :
If stacking the Olympus on top of the Olympus I/O, the feet of Olympus may injure the surface coating of the Olympus I/O?
I guess this may happen no matter it's anodized or powder-coated because the Olympus is so heavy.
Are there any thin materials that can be placed between the feet of Olympus and the top surface of Olympus I/O for protection yet with minimal sonic side-effects?
Many thanks!
I have had no issues that I can see with the O stacked on the IO. That was the way recommended by Taiko and shown in all of their pictures. Mine are anodized silver
I quite worry about after some time, there may be marks left on the top surface of the Olypmus I/O.
You could also decide not to stack them if you have the shelf space to do that.
Ideally they should be placed separated.
But with O, O I/O, router, switch and the associated LPS... etc, rack space is now becoming insufficient.
:rolleyes:
Very true. Someone needs to offer a mini rack for the smaller items like the router, switch and LPS so they can all be on one shelf.
Like you, space for me was the mitigating factor. I had no choice but to stack. I suppose that with time marks might be left but right now if that is the case, I cannot see the marks. I took the advice of Taiko which was to stack the O on top of the IO. That's the way things will stay for me so I dont have any heart burn until some Taiko product replaces the O/IO and hopefully there will be a trade up program at which time the O and IO will got back to Taiko. IOW there is no issue. Stop worrying
Reactions: CKKeung
...I am still considering final landing positions and isolation bits for the various pieces, but I made this stand, and I don't think it would be too difficult to find something similar commercially. Or have one made. This is just red-oak, maybe 100 bucks in materials? Posted to stimulate ideas for others. 10x15 inches.IMG_2475.jpeg
SHILL ALLERT: Arnold Marr is a gem! Lots of experience in high-end audio and rack building. He is that unique blend of artist and craftsmen. Does custom design and build at a reasonable price. SHILL ALERT ENDING...
...I have been considering building something much lower, but wider. I would like to reduce the visual "footprint" a bit more. Initially, I thought the NAS would be too noisy, even with SSDs, in the audio bunker, but it's A-OK. That changed the amount of linear shelf space I forecasted. Also, having the connections facing rear-ward is visually better, but man-o-man when you want to try a cable or different DCD filter, it's a suicide mission.
Reactions: dbeau and John T
This is one of the single biggest reasons why I never liked vertical stacking in a condensed space. When designing shelving/racks if possible, the ability to have access to maneuver is paramount for me...
Many thanks!
Hi @CKKeung ,
I understand your concern. This is one of the reasons we picked Acrylic as the footer material. It’s a “hard” material avoiding the mass-spring resonance which makes performance more predictable, especially when taking a rack/shelf into the equation. Acrylic is still softer than anodised or coated Aluminium and therefore should take the damage. Softer, rubber materials can stain surfaces over time. It doesn’t leave many other options, fabric, velt, leather are good options from preventing damage, but those do leave a very audible footprint unfortunately, paper is the best option, preferably a thicker craft paper, and has minimal impact.
So far, we have not managed to damage anything with the stock Acrylic footers with plenty of stacking action, just make sure they’re clean / dust free before stacking.
