I agree, that particular powder coat appears too thick? (visible on the top of chassis)
Yes, it needs to be just a few microns thick, otherwise it covers up the texture of the bead blasted surface. The colour we got from Pilium, if we can match the surface structure that might be a nice option to offer as we have quite a few customers owning Pilium gear.
Reactions: StefanK and wil
I finally got my Olympus + I/O and I'm feeling pretty dumb here: I cannot seem to get Roon to find it, even though it's on my houses ethernet network. Anyone already tackle this one and can offer some tips? (So close....)
Having read the manual through, I sure don't see any guidance for this. I'm scratching my head.
Reactions: l3uzz
First off, congratulations!!! End of a long road.
2nd - have you checked your router, or used an app like Fing to see what IP the Olympus has taken?
3rd - are you using the Taiko router?
Is your Olympus and tablet/phone on the same network?
Reactions: MarkusBarkus
I will give you a call in a moment.
-Vassil
Reactions: audio42
For people moving from an Extreme to an Olympus are you backing up Roon from your Extreme and restoring that to the Olympus version of Roon?
If your playlists are in Qobuz, there is no need to do backup and restore.
If you have important playlists with your local files that you need to preserve, backup / restore will be the easiest way to transfer those from the Extreme to the Olympus.
Reactions: Taiko Audio and lwr
Left you a voicemail. Available to help if you can return my call.
No playlists anywhere. I was thinking more of how I have Roon configured, from the storage locations to the bookmarks to the customized display.
In that case, start from scratch and don't backup/restore.
There is a "Recommended Roon Settings" document in the Downloads section on the Taiko website.
Thanks, Vassil! I'll speak with you later to sort this.
Reactions: nenon
We wanted to proactively address a question we've seen coming up frequently:
"Why is my order X estimated to enter assembly later than order Y, even though X < Y?"
The short is answer is because order X is different than order Y. For a more elaborated answer - see below.
Creating these estimates is extremely complex due to many interdependent variables. To illustrate, even ChatGPT, when provided with all our data, responded:
"Unfortunately, due to the extreme complexity and interdependencies, I cannot reliably provide an exact final schedule that meets all constraints."
This underscores the intricacies involved. Currently, even minor updates to the schedule require about four hours of work by me.
Here are just some of the constraints we must factor into our production scheduling:
1. Different chassis finishes:
- Black anodized Olympus chassis
- Black powder-coated Olympus chassis
- Black anodized I/O chassis
- Black powder-coated I/O chassis
- Silver anodized Olympus chassis
- Silver anodized I/O chassis
2. We must predict:
- The exact number of each chassis type arriving and their arrival dates
- How many chassis will pass inspection
- Assembly capacity, factoring in daily fluctuations such as team availability (due to illness, personal days, etc.)
3. Customer preferences add another layer of complexity. Some customers change preferences between silver and black finishes, and others strongly prefer anodized or powder-coated finishes. Some want their unit delivered ASAP. Other have put vacation holds. Some want to wait until balanced analog out is available. It's a really complex task!
Based on our current projections:
- Customers who opted for black powder-coated chassis are slightly ahead of those preferring silver or black anodized chassis.
- Customers with a black powder-coated Olympus chassis without an I/O are slightly ahead of those awaiting an I/O, due to current inventory and production projections for black I/O chassis.
Please note that these estimates may shift back and forth in the coming weeks as new information becomes available. We will continue to provide weekly updates to keep everyone informed.
Lastly, some people have expressed concerns about how long it will take to get to their order. The real goal here is to set realistic expectations, give people timely updates, provide clear communication, and maintain full transparency. That’s all I am trying to do. If you are disappointed that your order is not in Week 1, I am disappointed too. So is Taiko. But as discussed many times, Taiko is at the mercy of external vendors for the chassis finishing, and there is no workaround for that.
We greatly appreciate your understanding and patience as we navigate these complexities to deliver your orders as efficiently as possible.
Since you mentioned ChatGPT. Try Grok 3 and try to enable the “think” function, maybe it will work? I’m not being cheeky (for once haha), I’m genuinely trying to help.
@nenon got me squared away in no time, saving me from my user's error. Listening to the XDMI DAC analog out now. Booker Little is even a little more Out Front already! Thanks, again, Vassil!
I don't know if this topic has already been discussed, but I can't find it. I'm wondering if I could fit my Center Stage feet into the gap left in the Olympus when I remove the factory feet. Can anyone tell me the inner diameter left after removing the Olympus feet?
Inner diameter is 90mm.
Reactions: gereric
