Yes the one on the right is closest. Maybe not quite as steep n angle. Sorry if it does not work for you but it's crazy good here.Mysterious stuff. Remeber to give it four days!Something like this?
Something like this?/---- Is my sketch. You lay one flat and lean the other one with it's inderside on the upper edge of the first one. They are next to one another but one is at about a 45 degree angle. BTW it is causing the room(?) to break in. Wonderful at first. Second day elevated (but tonally beautiful ) highs and no mid bas. Third day kind of fractured and fuzzy sounding. Day four absolutely awesome, there is not an aspect of SQ that is not vastly improved. I don't expect anyone to believe this until they hear it. IT IS NOT SUBTLE, at veast not here. Awaiting more so I can do this in side locations.
Did you orient the surface of the holostage that is leaning on 45 angle in a particular direction? For example, facing toward the listener.Yes the one on the right is closest. Maybe not quite as steep n angle. Sorry if it does not work for you but it's crazy good here.Mysterious stuff. Remeber to give it four days!
Thanks, Jeff. And you do this with all four or just with the one in the front and back? And I presume the angled Holostage is positioned in a way that the angled surface faces the room? So as if it „reflects“ the sound back into the room towards the ceiling with 45 degree angle?/---- Is my sketch. You lay one flat and lean the other one with it's inderside on the upper edge of the first one. They are next to one another but one is at about a 45 degree angle. BTW it is causing the room(?) to break in. Wonderful at first. Second day elevated (but tonally beautiful ) highs and no mid bas. Third day kind of fractured and fuzzy sounding. Day four absolutely awesome, there is not an aspect of SQ that is not vastly improved. I don't expect anyone to believe this until they hear it. IT IS NOT SUBTLE, at veast not here. Awaiting more so I can do this in side locations.
No the sides face the room. Like looking at the one on the right. Front and back of room. Still just vne in side locations and in front room corners. Maybe ut's better with flat surface facing into room- have not tried that.Thanks, Jeff. And you do this with all four or just with the one in the front and back? And I presume the angled Holostage is positioned in a way that the angled surface faces the room? So as if it „reflects“ the sound back into the room towards the ceiling with 45 degree angle?
My earliest experience with these things was like that only in reverse. In my case I brought the box from the porch into the listening room. My plan was to warm the system up listening to some music then unbox the goodies and try them out. What happened instead was an immediate, "WTF?!?!?!" The bass was ALIVE! I mean it was insane! How can.... wait, wait one [] minute... those things are still in the box but the box is sitting on a sub and the bass is ALIVE!!!Music listening day, and I was just sitting in my chair on the Internet listening to music. I said, hmmm, the music sounds flat. I looked up and realized I forgot to place my Holostage pods. As soon as I laid them out, everything was back to wow again. For me the holostage pods definitely work.
hmmmmmhi all,
I am not sure why this thread gets derailed every so often - would be nice to stay on topic!
I too am a new Member here and posted elsewhere but the Moderator pointed me back here. I got sick of late so didn't respond.
But decided to see how things are going.
I can repeat that I found the Halostages were impressive in my system!
Excellent bang for the buck - lower soundstage, more dynamic, impressive imaging, and vocals that make your skin stand up.
So pristine, clear, and live like.
And I wanted to second what Tuffy7 wrote above - the RCA Boxes (grounding boxes) are excellent as well!
Hooked one up to my second system and it definitely had exceptional improvements as a result.
I like that a few of you are now discussing different arrangements of the Halo's - may give it a shot.
All this to say - didn't know Krissy before reading some blogs - and then connected and took a chance.
So glad I did - her products are amazing and don't break the bank like some other manufacturer's which have similar effects with nano technology, and grounding, etc.
Gratifying to hear this is pleasing people. In my set up my best description is that they decrease the effective viscosity of the air in the room.I've been a tv news cameraman for a very long time, so I'm a visual person & tend to describe the auditory world with visual references.
For example, a jump in clarity for me is like placing a polarizing filter on a camera lens or, the greater the degree of immersion, the more it's like I'm swimming in the music. Above, below & all around me.
48hrs into the poster's double 45 deg angle suggestion & with 3 sets of 4, front R&L, sidewall R&L, rear R&L. Room takes a remarkable leap forward & deeper.
For those who have experienced the holostage effect, they will be very pleasantly surprised at the increase in dynamic range that the double 45 degree in this configuration brings to the party.
Another 24hrs on the latest set of holos & I'm sure there will be further enhancements.
Good stuff!
Thanks Krissy for many hours of enjoyment.
Aptly described Jeff.Gratifying to hear this is pleasing people. In my set up my best description is that they decrease the effective viscosity of the air in the room.
Viscosity of the air…..at what temperature and what is the relative humidity.Gratifying to hear this is pleasing people. In my set up my best description is that they decrease the effective viscosity of the air in the room.
I should say it FEELS that way. Not saying it literally does so.Viscosity of the air…..at what temperature and what is the relative humidity.
Aware of placebo effect I tried each arrangent several times- consistent and not at all subtle.Have ordered more to do the same on the side placement locations.
