Hello and good morning to you,
@nortberg.
I can see where you couldn't find it, as it is not specifically listed as a SDFB Pig Tail. There are only two options - the
8" Signature AMP Series PC and the
8" Takshaka PC. This specific length would be the replacement of the Pig Tail.
When you are at the page that is screenshot below, click onto the Cable Length drop down and select the 8" (
as depicted by the arrow in the screen shot below).
Here is the link for the
Takshaka PC 8" Pig Tail >>>
https://snakeriveraudio.com/index.php?main_page=product_info&cPath=5&products_id=297
Here is the link to the
Signature AMP Series 8" Pig Tail >>>
https://snakeriveraudio.com/index.php?main_page=product_info&cPath=5&products_id=38
My advice would be to reach out to Jonny, as (
depending on your configuration preference and country you reside in) you may need a C-13, C-19, Shuko, UK, or AUS type connector on one of the ends. His contact information can be easily found by scrolling down to the the bottom of any page I have seen so far on his website. Just click onto the "contact" tab. If you don't like emailing? Just call him to discuss what your specific needs are. He'll get you straightened out.
Tom
