garylkoh
Nope! Mine was one of the originals, without the turrets on the front.
This one then.
Did your arm cut-out sag?
This one then.
The Xerxes is a good turntable.
When it came out, many dealer gave up Linn for the Roksan.....
This one then.
Gary,
I still have one of those in my garage! Beautiful rosewood finish with the separate power supply and brown tint acrylic cover. Every three month it had to receive a few days anti-sag heat and force treatment and than it is good for next trimester! I never sold it because I did not to hear complains from the possible buyer! But it had a conventional felt mat - not this fancy one.
Curiously I also own a Zeta toneram. And yes, much better than people can imagine.
The 20+ version uses a similar solution. Touraj, the designer, came up with it independently. Shows that great minds think alike, but fools seldom differ![]()
Yes, it is a beautiful sounding and looking table - unfortunately, the first version had an arm cut-out that sagged. On mine (it's with a friend in Singapore) I fashioned a fourth support, directly in line of the stylus and on the opposite side of the bearing. Seems to work - I used a 60 durometer rubber puck and a screw to adjust the height.
Gary,
Thanks for the advice.
I have tried a similar approach with a large Audioquest sorbothane puck - after all the (hidden) Forsell suspension is made with these pucks. Unhappily it killed the lively sound of the Roksan + Zeta combination. Perhaps the sorbothane damped the board too much. I will try it with an harder puck.
Touraj have new Blobs to replace the original ones's http://www.roksan.co.uk/roksan/roksanpage.php?pageno=40
I used them rebuilting my deck and hapy with the result.
As far as fixing the sagging plynth, I took that way excepted that I use a carbon fiber washer
Yes, sorbothane kills the lively sound of the Roksan. I mentioned 60 durometer because that's what I landed with that sounded the best to me. I only had access to 40 and 80, so if you can find 50 and 70 durometer, one of those might sound better to you.
Most small shock absorbers do not refer the durometer grade. Do you have any specific recommendation?
An other tweak I have done on my Roksan was to replace the MDF base with one made of Corian.
