Just wondering what the normal temperature range for System and XDMI batteries is...?
As charging/discharging has a negligible effect on the temperature of the batteries we use, they will be at the same temperature as the chassis, between roughly +12 and +20 Celsius over environment depending on usage, like redbook or dsd512 playback, surrounding airspace etc. The recommended working range for full capacity is between -30 deg.C to 60 deg.C, however the system motherboard will start throttling and shut down before you can reach that temperature, it will top out at 52-55.
