Are you using both the Altaira Signal Grounding hub (for digital) and the Altaira Chassis Grounding hub (for non digital) or just the Chassis hub?Another data point : the Olympus does not gain much by grounding. The Altaira to left binding post induced a major drop in dynamics, and a collapse of depth ( from 7m to 2m, hard to put numbers on those ). The router and switch benefited from grounding, although not the Taiko distributor, nor the power supply that powers the distributor. In short, the Olympus is not taking well any of the power supply in the system being grounded, so there must be something in relation to isolating the grounding plane for the signal chain. I believe Emile had already made this comment in the documentation.
It is a dual signal hub, one for digital and one for analog. For reference, it is the first time I observe the Altaira not improving significantly a component by reducing noise.Are you using both the Altaira Signal Grounding hub (for digital) and the Altaira Chassis Grounding hub (for non digital) or just the Chassis hub?
I haven’t, but it was tried at the last Munich— and the USB was preferred.Has anyone of the Aries Cerat DAC and Olympus Server owners compared the USB output with the AES/EBU (or with the SPDIF)?
Thank you. I have the two units as well and I do have the O plugged in to the signal hub as well as the router and the switch and the DCD. I have not compared with or without the grounding cables connected as I just connected them and it sounds amazing with them being connected, but upon your observation, I will do some testing.I haven’t, but it was tried at the last Munich— and the USB was preferred.
Hi,
Is taiko working with ch precision for the XDMI connection?
"Black Olympus servers finished: 34.1, 40, 42, 49"
Shipped? If not, when?
I wasn't planning on trying the XDMI AES out to the Kassandra because USB is sounding so good. Also, I didn't want to flip the I/O upside down in order to replace the analog daughter card and I currently use the AES input on the DAC for the CD transport. But now I'm going to have to give it a tryNot by me![]()
Interesting…. I should have specified it was Stravos who preferred the usb.Not by me![]()
Indeed, never underestimate the power of cognitive dissonance, particularly in short-term listening sessions. In a human consciousness model where, whether we realize we are doing it or not, we are always trying to make sense of the outside world by recognizing patterns, sorting and categorizing, we often prefer the familiar and comfortable over something new and outside our normal experience.Additionally USB is the type of sound we’re completely accustomed to as it’s being used in 99% of file based / streaming digital playback systems. And it will remain to be for quite some time.
Hi QuantumWave,Another data point : the Olympus does not gain much by grounding. The Altaira to left binding post induced a major drop in dynamics, and a collapse of depth ( from 7m to 2m, hard to put numbers on those ). The router and switch benefited from grounding, although not the Taiko distributor, nor the power supply that powers the distributor. In short, the Olympus is not taking well any of the power supply in the system being grounded, so there must be something in relation to isolating the grounding plane for the signal chain. I believe Emile had already made this comment in the documentation.
