Are those required adapters approved for use by Lampizator? There have been some inferior quality ones that could hurt performance or the device. Whose are they manufactured by?ECC40 on the left, E81L on the right and AZ4 rectifier.
They are manufactured by us. I’ve been using them for a while without any problem. A lots of WTB members and some Lampi dealers also use them.Are those required adapters approved for use by Lampizator? There have been some inferior quality ones that could hurt performance or the device. Whose are they manufactured by?
The ECC40 tubes sell for $40-50 each for Tungsram and Philips up to $150 to $500 for rarer versions. The E81L tubes are generally really inexpensive at $10 each. The AZ4 rectifier is generally $25 to $30. Are these the low cost alternative tubes that are superior sounding with adapters in the Poseidon or the more expensive versions such as a mesh plate AZ4 which is rare and very expensive or the high end Valvo or mini-watt Philips ECC40s?They are manufactured by us. I’ve been using them for a while without any problem. A lots of WTB members and some Lampi dealers also use them.
I like the ability to purchase more common and inexpensive tubes. The ef802 sells for $3,000 to $6,000 for a set of 8 and one Valvo G2504 for $2,000. For wealthier folks. I chose the Westminster Labs REI as sounds as good as any tube amp I've experienced but solid state/no tubes. A 33,900 investment good for decades.This the low cost versionWith better tubes Posseidon will sound obviously better. This is just an example that you don’t have to spend a fortune to make superior sound. Compared to the stock tubes the difference is huge, like having a totally different dac.
I’ve tried the Posseidon with ef802 tubes too (you need 8) and Valvo G2504. With them another big jump.
then take ef804s if you like that pentode sound, they are in the best studio amplifiers in the world. you need a double noval 9 pin socket. the ef 802 is much more expensive because it is popular for neumann microphones, every musician or recording studio wants it because there is no alternative.
Product - BTB - Elektronik
EF804S Audio Special Pentode Verantwortlicher(EU): Antiquität Hersteller geschlossen,oder unbekanntbtb-elektronik.de
I’ve tried both tubes. The ef802 was clearly better.then take ef804s if you like that pentode sound, they are in the best studio amplifiers in the world. you need a double noval 9 pin socket. the ef 802 is much more expensive because it is popular for neumann microphones, every musician or recording studio wants it because there is no alternative.
This is only due to the inappropriate working point of the device, otherwise the race would have ended differently. Trust me.I’ve tried both tubes. The ef802 was clearly better.
Probably what you really want to know is what they are in the context of what makes a difference to the sound quality.New to the hobby
can someone explain on the Poseidon DAC
What does the Rectifier tube do?
what does the Octal tubes do?
What does the Novak tubes do?
Yes that is what I was asking thank you Very much!!Probably what you really want to know is what they are in the context of what makes a difference to the sound quality.
Rectifiers convert AC to DC; they actually make a substantial differnce to the sound so changing out a cheap one for something of better quality can make an appreciable difference and it doesn't have to cost a lot of money. It's generally accepted that the Ricado Kron Anniversarry 5u4g is one of the best rectifiers you can buy, but individual tubes cost £400 and they do eventually need replacing. New old stock items from the past can cost £70 and sound almost as good.
The Noval tubes are on the input stage of the DAC and the Octal tubes are on the output stage. It is the Octals that make the biggest difference in sound and are the ones to experiment with rolling.
If you're using the unit single ended you don't need the full compliment of tubes in place; you can use two and two plus the rectifier.
When you say, Single ended ??
I am using USB in and balanced out
So I use my Mac Book Pro as my streamer into the Intona 7055-C which you probably know is a Galvanic isolator which is USB. I do also have the Holo Red which is not hooked up (not as simple) which is a streamer and Galvanic isolator and does have SPDIF. But correct me if I am wrong I use HQ Player for up sampling and SPDIF I thought did not sample up as high?Well, then assuming your inputting into a true balanced amp, you'll need the full compliment of tubes on both the input and the output stages. May I also suggest you explore using SPDIF rather than USB? If you can get hold of a good SPDIF cable to try you might be surprised with the results.
The GEC 6j5 tubes are apparently the ones to aim for:
I will check it out.Well, we're moving a little away from my technical expertise, but, yes, in general I think you're right, SPDIF doesn't convey high res files. Except, it does. At least, it does from my music server, but that's becuase the guy who designs and builds it - Lucas Audio Labs, LDMS Minimax - is a bit of a genius and has worked out a way to play high res files over SPDIF. I had to have an upgraded SPDIF output retrofitted to the music server, which wasn't cheap (about $1500) but it was a very worthwhie upgrade. I can play up to DSD256 via the SPDIF output. I honestly couldn't say how this is done, whether it means they are converted to something lower before output or if the high res file is now going over the SPDIF. I don't know, but i do know it sounds wonderful and I much prefer all files, even high res ones, played over the SPDIF cable compared to USB. And I've A-B-A tested USB cables up to about $8k against my $3k SPDIF and it was only at that level did I start to think the USB pulled ahead.
I used to use my Macbook Pro before I took delivery of the LDMS (there's a thread here dedicated to that unit and an excellent full length review here) and was floored by how much better it was. It was a monumental shift.
Out of interest, how long ago did you place the order?Hey guys, my Poseidon arrived on Monday and is burning in with amazing results. I’ll share some pics soon and describe what I’m hearing. It has exceeded my already very high expectations.
