I have experienced the same thing with Qobuz recently and the timing seems to be similar -- 6 to 12 hours into a session with Qobuz. I haven't yet pulled the plug on my Tidal subscription so I will check that later this evening.
Steve Z
Roon just released an update:
“We’ve resolved an issue in version 2.0.43 that caused disruptions to playback queues in for zones.”
2.0.43 was released 8 days ago so this could be the culprit. I’ve installed the update and will let it run overnight again.
Reactions: audio42 and cmarin
I'm confused/perplexed here. I do NOT have the Olympus yet. I've been listening to Qobuz for several days in a row including all of yesterday. No issues whatsoever. Tablet 2.0 (build 1480) Extreme version 2.0 (build 1483). I promptly do all updates upon notifications. No issues on my end. Are you certain yet if this is a Roon issue? Or is this Olympus/Roon Version related?
Have you been listening all day without modifying your playback queue? Aka not changing tracks / not operating your Roon remote?
I noticed an issue with random stoppage as well, but put it down to network outage - interestingly since I did the Roon update 2 days ago, I haven’t had any stoppages in Roon playback as I’ve been burning in some new cables and just had things playing non-stop.
In case of interest, here is an extra data point on the Olympus. I have been experimenting with a selection of power cables. Irrespectively of the power cord, the Olympus sounds absolutely marvelous. For me the rubicon has been crossed in terms of realism. I had good success with the Extreme with the Shunyata Omega XC, the Extreme was really scaling well with raw power. Here, I found a pairing made in heaven with the recently upgraded Sablon Prince 2025. I have to say Mark has been really down playing the amplitude of the upgrade: his new cord brings an entire palette to the mid-range that combined with the Olympus agility is really to die for. I can’t imagine a better pairing and the Sablon Prince definitely is here to stay! Hopefully this may be helpful for others to experiment. My only point of comparison as to how power cords affect the Olympus is akin to the Taiko router, dynamics is always there, but the subtle balance between textures, timbre, and the tonal palette remains largely affected by the choice of cord. BTW Mark also has now an excellent DC cable for the router/switch combo that I had missed, another great pairing :) i am hoping that one day someone will provide an explanation of this elusive phenomenon, electrical wiring tuning the audible properties of a distant magnetic coil, I am scratching my head!
I'm always using the remote, jumping around, exploring, skipping tracks...No issues..BTW I also have Tidal, no problems with that either...
Indeed, there is (was) no issue with that. The issue is if you leave it playing unattended, it will (would) stop after somewhere between 6 and 12 hours of continuous playback.
Reactions: John T
OHHH, got it...Sorry for the confusion...Guys who are breaking the units in...Got it...
Samsungs don’t work with the BMS app, we only found out last week, on the todo list to figure out why.
We have Samsung phones and tablets only in my house. Is it necessary to access the BMS app to use the Olympus or can I just let it at factory settings and use it plug-and-play?
Reactions: Jens
It can be plug&play, we pre-configure it to the timezone we ship to and configure it to charge between 0:00 and 7:00 AM. If that is ok for you there's nothing that needs to be changed. Besides that I don't think it will be very difficult to make it work on Samsung devices, we're on it.
Reactions: M27HF and simorag
...my BMS was set to Dutch Time (which I always thought was time for beer), so in my case I preferred it to local NY/US. But the Taiko fellas are on the fix and it can't be much to resolve.
Oh really, they must've configured yours on a Friday afternoon then (beer time) :rolleyes:
In my case (OP), my interruptions do occur in the course of a session where I am regularly selecting new albums, always from Qobuz ( I have not set up my local files yet and I do not use Tidal). I do sometimes interrupt those albums, and change to another. I have noticed no correlation between what I am playing, or how long the playlist might be. My interruptions are not requiring 6-12 hour playlists. My Qubuz has the latest version.
Can it be (for some reason) Qobuz is arbitrarily timing you out based on a continuous use timer? When you break this timer for whatever reason, the time starts over? I have no idea..
I, occasionally, have this issue with the E...
I've experienced the same with my Statement and streaming radio in the past... music is on 24/7 in the house.
Since Innuos has had multiple updates, the issue seems to have resolved itself.
Reactions: John T
Wholly concur with you. My updated King cords double up the goodness that XDMS on the Extreme provides.
Realism taken up another few notches.
Can you try updating Roon to the latest version?
If you leave the Olympus/IO always on there will never be issues or even have to look at the Taiko battery app
Reactions: cmarin
My Roon server and App are both latest version ( I checked on Roon "About" before the last post). Says 2.0 build 1483
Ok, if that doesn’t help we can examine your Roon logs and see what’s causing the interruptions. Could you be so kind as to open a support call by emailing support@taikoaudio.com ? If you include your Olympus serial number and symptoms the crew can take a look.
