We more or less will have to, it’s not allowed to discuss politics on this forum, but the reason why should be obvious. We do have a second anodiser now, a really significant amount of people switched to black, the only remaining issue is our staff shortage, more job interviews next week, fingers crossed, maximum effort!
All very much appreciated! Looking forward to receiving #120 Olympus/IO.
Reactions: Taiko Audio
We have a fulltime employee now ( @JulienVermeiren ) JUST for shipping, and a standard work week doesn’t cut it…
Julien was of great help in following up and providing updates on the shipping of my unit. Great choice!
@JulienVermeiren is a great addition to your team! I needed to delay my shipment by a few days due to travel, and Julien managed that process perfectly. Of course the weak link in all of this is FedEx, where delivery either goes as smooth as silk, or all hell breaks loose.
My unit (#37) arrived yesterday in 2 days from NL, but my local FedEx team seems to be nonplussed how to deliver it to me. They suggested I come pick it up (with my back, no thanks!) The issue here seems to be the unit was sent to the FedEx EXPRESS distribution center, not the FedEx FREIGHT distribution center.
I'm sure they will sort it out early next week, but every FedEx issue seems to be unique, suggesting the company has issues with their "last mile" delivery infrastructure. Sadly, there does not seem to be an alternative, as UPS and DHL are equally bad.
if you ever want a first class courier shipping try World Courier , expensive, sure, but every time I used them it was well worth it...sure stuff goes wrong with them too, but they care about resolving issues and getting shipments delivered.
Does anyone use Starlink as a dedicated isp for their kit?
Not dedicated as in audio-only ISP. I use Starlink as the ISP for my entire home and segregate the audio-only behind the Taiko router/switch/DCD combination.
Steve Z
That copper on BLACK is simply sweet!:)
You'll have to put your Olympus on the rack back-to-front then to admire that combo (which I agree, looks great)
Steve Z
If I found an Olympus on the street, I think I could muster the strength to pick it up and run with it. Where there is a will…
I don't want to interrupt the on-going discussion about logistics for something as mundane as a few comments about sound quality, but here goes.
Regarding Olympus and PGGB files. I've been doing some comparisons of PGGB-processed tracks to original 44.1 tracks with my Olympus/XDMI analog daughter card. I've got quite a few hours on each, having them installed and playing Roon Radio 24/7 since delivery, with a few short periods to swap cards and play XDMI SPDIF to my Vivaldi. As stated before, the Vivaldi APEX DAC and Clock are for sale (the Cybershaft OP-21 reference clock is sold). So Olympus/XDMI analog is my way forward for now.
First off, I'm not hearing the dire SQ drops I was expecting as sample rate/file size goes up. But, in some formats I'm not hearing the SQ improvements touted in the past for high bit rates either.
I've been running the comparisons using 12 44.1 tracks I've ripped from CDs and with which I am very familiar. At least 7 of these tracks are music that wasn't treated very well by the original mastering from analog to digital or perhaps were recorded digitally to begin with. The other 5 are just things I really like and are recorded well enough, because I can only stand so much A/B B/A listening before I start to lose the will to go on living. So they are some blessed relief and enjoyment from the testing.
The challenging-to-listen-to tracks all get fatiguing because of harshness, brash or forward sound, edginess, flat perspective or all of the above. What I've come to refer to as typical digital nasties. These nasties are particularly irritating to me when they are associated with vocals.
So I have looked to PGGB in the past (pre-Olympus) to help tame or ameliorate these problems, at least to the point of making the tracks easier to sit through if not downright enjoyable.
PGGB Plus as the public release is called had been a big improvement in terms of its success rate at improving digital music for me on Extreme. Not everything can be completely helped (some things are truly wretched in their original form) but almost always DSD files produced by PGGB have made listening much more enjoyable.
That hasn't changed. I am not going to convert my entire music library to DSD512. Really great sounding albums in 44.1/48 or 88.2/96 kHz PCM format with Olympus don't seem to need the help of PGGB DSD and SQ improvements if any are pretty small and to me, not worth the time or the penalty in disk space to worry about.
However, those less the stellar sounding original files very definitely benefit from conversion to DSD and the magnitude of improvement in lack of grain, naturalness, and importantly in reduction or outright removal of edginess and harshness goes up as the bit rate goes up.
So these comparisons wouldn't take forever (reference: will to live) I compared originals to DSD128 and DSD512 and skipped DSD256. Whether the deltas would be even larger were Olympus not sensitive to processor load is moot point -- I have no way of knowing that. Suffice to say, for me DSD processing is worthwhile for my problem tracks and albums and I will continue to use PGGB at DSD512x1 to do so.
High bit rate PCM is interesting. I decided to cut right to the chase and instead of producing several test folders of upsampled/remastered test tracks at increasing bit rates, I went directly to 32 bit 705.6/768 as a best case/worst case test.
While I found high bit rate PCM did make improvements to certain non-problem attributes such as longer decay tails, increased ambience and air, a great sense of ease, etc the reduction in edginess and harshness if it was present in the original was less, in some cases much less than with PGGB DSD.
Plus, while I hear the DSD-processed tracks as very full-bodied with saturated tonal colors and lots of natural texture, in comparison high rate PCM sounds lighter, almost thinner and not nearly as vivid.
So, I offer this as an additional data point for those using or contemplating using PGGB with library files with their Olympus and Olympus I/O.
Steve Z
"Where there is a will" -
there's normally money...
Don't hurt your back.. Hire someone. :)
I've had the O-I/O for close to two weeks now. I'm not going to get into the sound quality yet (yes its great and getting better), as I'm finding that things are still breaking in with the XDMI digital AES out, but wanted to add a quick note on the packing and set up of the O-I/O.
1. Unpacking and setting up on my rack. Agree about the "don't hurt your back" advice from RUIN*ish. I hired my trusted moving outfit (3 guys) to bring the crates to my home, unpack and set up on my rack. Everything was perfectly packed. No damage. Nothing was missing. Well done Taiko.
2. Setting system up. It took a little over an hour to unpack and connect the O-I/O, and get it up and running, including connecting ROON and to the NAS. Music started playing without any glitches. Thumbs up Taiko team!
3. Couldn't connect initially with the BPS app to the battery through Bluetooth. But after some help from Christian P, and clarification about the minor effect on sound quality during charging, I left the defaults in place (charging takes place from 12pm to 7am) and haven't worried about it at all since. The system is always well within the voltage limits without having to give it a thought. Another thumbs up for the Taiko team!
All in all, a painless and quick set up. And haven't had any glitches since. Great job Taiko!
I'm going to swap out the I/O cards out next week to try out the XDMI analog out. And will report back - but apparently it may take a while for the analog card to settle. We shall see. But I'm encouraged by Old Mustang's findings relative to his dCs system.
Mine was delivered to the middle of my driveway (look out the window “I wonder what that is”). I literally had to summon this will ;)
Fantasy becomes reality. At least you didn’t have to run too far. :p
I’ve been pondering what my mid-winter delivery might be like. The easiest way to get heavy things into my lower level listening area is to go around the house through the walk out patio door. This is about 200 ft. from my driveway - through the snow. I’ll need a sled. Maybe fit skis to the bottom of the pallet? Running in snow shoes? I’ll have to do this when no one is looking.
My listening area is also on the lower level and I have to go around the house and to make things worse, I have a steep slope which goes straight into a swampy area. Simply cannot imagine taking this in a dolly me and the olympus sliding into the swamp. I will most likely make a path in the snow in a way to prevent me from sliding. Here is hoping the excitement makes the move easier :)
  • Wow
Reactions: 2ndLiner and ctydwn
Hire 2 muscle men. It’ll be the best $100 you’ve ever spent on stereo. Call it a tweak and it’ll make you happy. Mine had to go up 17 stairs and then onto the top shelf of my rack. It saves energy for you to do the cable connects after they’ve done the grunt work ;)
Just getting the Olympus to the patio is the challenge. The rest, I can manage it since the Olympus goes on to the lower rack. I might do just that. Oh my, 17 stairs does need extra hands.
Reactions: ctydwn
i can’t find ‘muscle men’ here on google in bay area. used moving guys in past for the 20 minute job to get heavy components from garage up the 15-18 stairs but cost $500-600 usd base (without insurance). going to use some sort of improvised system to get the olympus up stair by stair as i did w extreme. will be ugly but thankfully also when no one is looking :oops:
You might want to look into Stair Dolly. You can get them with a capacity of several 100 pounds. Someone from the bottom can give a little push while you are pulling the dolly handle on the way up? Just a thought.
Check your local tool rentals for Stair dollies or other material handling equipment you might not want to buy. Appliance stores usually have a few and you might be able to arrange an informal rental from one of the warehouse guys.
Steve Z
anyone using Android phone or tablet for Taiko BMS connection to Olympus ? I have Samsung S22+ phone and a 2 year old Samsung tablet -all the correct settings and yet neither can connect for BMS app even when within a foot of Olympus. After several failed attempts, I tried my wife's Apple I-12 to connect and even from upstairs the BMS app worked fine...
Samsungs don’t work with the BMS app, we only found out last week, it's on the to fix list already.
  • Wow
Reactions: simorag and audio42
@dminches , we’re updating on this forum, see above for the last.
This to put an end to the mayor support headache the webpage creates. It looked like a good idea but it turned out to be a very bad one.
We are contemplating moving to a subscription based e-mail system, working on that now.
Meanwhile Silver Olympus servers (without I/O): 41.1, 47, 51, 58, 63, 65 shipped to the hazardous material handling company while Black Olympus servers (with 3 I/Os) : 34.1, 40, 42, 44, 49, 60 are being finished. Silver I/Os are expected to arrive this Thursday but will need to pass QC. And eagerly awaiting the arrival of a rather sizeable black batch.
Thanks Emile. No need to take up more of your team’s time. Things really seem to be moving along.
