Seeking some help from one of you technical wizards, please. I'd love to get a very explicit description of how to set up port forwarding in my TaikoRouter (or whatever it takes, if that's not the solution) so that Roon can 'see' my new DS224+ NAS on my home network. I've attached it to my TaikoRouter successfully simply by figuring out the IP address for the NAS within the Taiko network and then mapping a new network drive to the NAS on my Extreme, then pointing to that drive within Roon (this is all in preparation for doing the same thing with my Olympus-I/O when they arrive). But I'd like to at least experiment with keeping the NAS on the home network side for various reasons--just cannot figure out how to do it. I assume that it probably involves adding some port forwarding to the Taiko Router, but the example provided in the Taiko documentation just doesn't seem to help me get there.
Many thanks!
No port forwarding needed. Actually no configuration on the router is needed at all. The default configuration is fine.
You attach the NAS to your home network, make a note of the IP address, and use that IP address in Roon on your Extreme.
Note: you need to use the IP address, not a hostname.
As far as I know, the only time this did not work out of the box are those that have a home network on the 192.168.100.xxx network (which is the same IP range as the Taiko network). Starlink does this. That's very easy to fix as well, but a topic for another post.
