On a different but related topic -- I have been successfully playing digital music via SPDIF from the XDMI digital daughter card. However, when I unplug the SPDIF cable and try to use an AES cable my Vivaldi gives me a "Non-Audio" message and no music plays even though Roon says it is playing an active track. dCS advises me that my set up of the Vivaldi for AES is correct.
I will try a different cable to be sure (though the one I have is brand new). Is the XDMI digital daughter card AES output simply in parallel with the SFDIF or are they being processed or routed differently inside the Taiko XDMI digital daughter card?
The reason I ask is that dCS tell me the "Non-Audio" flag is one of several flags in the bit stream, such as "Single-AES", or "Dual-AES" and that it seems strange to them the Non-Audio flag would be set for AES but not for SPDIF.
Regardless, SPDIF to Vivaldi from Olympus sounds great!
Thanks!
Steve Z
Steve, may I ask - when you first started listening to your Olympus with your first remarks on what you were hearing, was that on aes/ebu or spdif? Also, what has been the most recent NAS you’ve been using, if any, and how’s your research on a fanless variant going?
Emile, on an aside, if I choose to use my dcd to power taiko router, switch and twin hard drive NAS of 22W access/running consumption, might a farad super 6 power supply work for all three with sufficient overhead? In line with everything I’ve been reading about power and how too much of it damages sound quality, I’m researching a power supply that is just enough (with peaks) to power the dcd and the threesome it will feed.
Thank you both! - kevin
Hi Kevin,
If you are asking me -- Steve Z -- I first started listening to Olympus via the XDMI analog daughter card after about 100 hours of letting it play Roon Radio with my system amplifier off. I continued to listen to Olympus analog for a few evenings, then switched daughter cards to XDMI digital (AES and SPDIF). I used SFDIF.
I haven't been using a NAS yet -- that was on the to-do list today but I just stopped working on the higher priority honey-do list to unwind a bit and get ready to fix dinner.
So far all of my listening has been by streaming, primarily from Qobuz with maybe 10% Tidal.
I haven't done a lot of research and may just end up shamelessly copying what David (@dminches) has done -- get a two bay fanless Synology that runs from 12VDC and power it from one of my DCD outputs. But first I'll fire up one of the NAS in my office across the entry foyer from the living room and spend some time listening. The several NAS in my office have one big advantage -- they're long since paid for!
Steve Z
I wrote that check during the intial Roon roll-out some years ago to get the discounted life-time membership.
I finally feel like that decision was validated.
Steve Z
Same here. Early lifetime adopter of Roon. Best $500 I ever spent on hifi in the past 40 years. Roon has had its share of teething problems, and I've suffered through numerous issues especially in the early days. But, of late, their updates have become more reliable, and I no longer dread updating to the latest release. Occasionally I have to restart my Roon Rock server, but thankfully I haven't had to reinstall from scratch in a while. All that said, I am in no rush to get rid of my physical media (> 6000 CDs and SACDs, many not on Roon). I still like the bullet proof reliability of physical media playback. With Roon, it's still subject to sporadic wifi outages, playlists and albums disappear all the time. I view Roon much like Netflix. It's a nice sampler of music that I don't have. But if I find an album I really like, then I have to get a physical copy or a download. Roon is no guarantee that the album will be available to you in perpetuity. If you are. long time collector, I can't see Roon being the basis of your music existence. It's too unreliable for that. But, as a convenient way to sample a wide range of music, it's great. To dig deep, you need to get into physical media. That's not changed in 40 years, and likely never will.
Reactions: MusicFellow
Hi Kevin,
Steve Z
Thanks for that Steve, and yes, I did mean you : )
Reactions: oldmustang
@Taiko Audio Emile, did you test having the NAS on the taiko network vs on the home network and, if so, was their a sound difference? Moving it out of the room has some advantage from a shelf space perspective.
It appears there’s no noticeable difference, atleast nobody appears to notice any difference relative to qobuz/tidal whichever way they use their NAS.
From a theoratical POV I can think of benefits to each approach, perhaps those simply cancel out, or just don’t matter at all…
If I was in the luxury position to spend time getting to the bottom of this (aka if I was seriously bored) I would analyse how the NAS loads the LAN side versus the WAN side.
In the same manner there can be several degrees of benefits to using the upstream wi-fi to control Roon versus using the Taiko Wi-Fi. For example if you use an Ipad with a lot of installed apps, with a lot of syncing and background activity, creating network load of some significance, and/or you use it for other activities like internet browsing, watching youtube videos etc, WHILE listening to music, you may be better off using your home Wi-Fi.
But a whole other aspect to this is the Olympus + network stack is just much more immune to network traffic then we ever achieved before, this alone may make the actual NAS location irrelevant.
I’m anxiously waiting for someone to report a significant impact from a specific scenario to investigate, that would qualify as a proper use of my time ;)
I don’t know how much current that can supply but it would need to be 2A continuous on 12V minimum assuming your NAS runs on 12V. I would chose a powersupply without supercaps personally though, if you’re asking me. That is a 180 degree approach to the one we’re taking with our network products and now the Olympus, being to minimise capacitive energy storage.
Reactions: Armsan
I plan on moving my NAS to my home network and will report back. I have been listening to it connected to the taiko router and DCD.
Hi Kevin,
Steve Z
Steve, do you prefer the the digital aes/Vivaldi dac to the analog card to pre amp?
Reactions: Dezy
Few issues with O + IO
1.
After logging in to my Olympus with Roon I found ZERO of my Playlists.
I have found Ray-dude public test tracks so I use it now .
Great music Ray !
Will ask Ed to help or someone from Taiko Team.
You will have to create a Roon backup of your Extreme and restore that on your Olympus.
A very quick and easy way to do this is by using a usb drive, plug it into the Extreme, log into Roon and tell it to create a backup on your E: drive, then plug the drive into the Olympus, log into Roon and restore the backup from E: . Do not hesitate to contact us if you need any help with that.
2.
My IO AES works flawless to my Totaldac D-24.
Unfortunately Spdif is dead for some reason. There is no signal nor clock.
That is really baffling, @oldmustang reported something similar but in his case only SPDIF works, not AES/EBU. Perhaps you two should switch output cards :p Joking aside, SPDIF and AES/EBU are both active, at the same time, there’s no feedback or anything checking if there’s anything connected to either port. If one works, so does the other. We can ship you a different card if you want to try but I very strongly doubt that will make a difference. I assume you did select the right input on the Totaldac reclocker?
3.
BPS app on new android phones such as Fold 6 is not recognizing any of the batteries. Bluetooth sees them as devices but not the app.
Is permanently trying to find them but can't for some reason.
The back door is to use older ipad or phone and it works .
We’ll look into this, any more devices you tried apart from the “Fold 6” ? We did test a recent different Samsung phone.
Reactions: Kris
Hi Wil,
A concise question deserves an equally concise and to the point answer.
I do not prefer XDMI digital > Vivaldi DAC over XDMI analog. Just the opposite in fact.
So much so that I will be listing my Vivaldi APEX DAC and Clock, and Cybershaft OP-21 master clock and the associated clock cables for sale later today.
The (slightly) longer answer is -- I tried to give the dCS stuff a fair trial however at the end of the day while XDMI digital > Vivaldi is the best I've ever heard digital playback with Vivaldi sound, it is still second place to XDMI analog.
I tried several digital cables, two different preamps, made sure I have very close to the same break-in hours on each daughter card, checked the volume with both XDMI digital and analog daughter cards on a track by track basis with a quality measurement mic and mic calibration curve into SoundTools' SPL module to ensure I wasn't favoring (or dis-favoring) the loudest track, ensured proper absolute polarity with each daughter card swap, etc.
And that is not to mention running the gamut of Vivaldi's extensive filter and mapping settings to find the most pleasing (at the end of the day, I wound up right back at my long-term settings for the DAC) or in some cases, least objectionable DAC settings.
The clear preference for me is XDMI analog.
Even if the comparison had been a tie it would not have affected my decision to move on from Vivaldi. Vassil (@nenon) said it best in another conversation (not his exact words but hopefully close) -- very expensive DACs as we know them now represent a top level for that particular paradigm, while Taiko's XDMI analog is just the bottom level entry in a new path.
This is particularly so for me since no matter how good it might prove to be, dCS' new flagship Varese line is beyond what I am willing to spend on a DAC-based digital playback system. While I am open to other solutions such as Lampizator, Aires Cerat or MBL's adoption of XDMI into their DACs at the present time I prefer to wait and see (and hear!) what Taiko may come up with in the future.
So, probably more than what you wanted to know, but that's how I hear it in my home.
Steve Z
@oldmustang I am very curious how I will feel about XDMI Analog vs. XDMI Lampizator Horizon. I won't know until 2025 though.
Hi Wil,
Steve Z
Exactly what happened here, but with a different DAC brand.
1.
Great music Ray !
To which Emile responded:
Kris, I apologize if I misled you. Emile is right, you need to use your last good backup from Extreme to restore all your playlists.
After looking more closely at my Playlists in Roon I see they are all Qobuz or Tidal playlists and not lists I made up using local library content. Qobuz and Tidal lists are also stored at the respective streaming platforms and when logging in to Qobuz or Tidal, just as they furnish Roon all the tracks the user has favorited at the streaming platform, they also supply the Qobuz and/or Tidal playlists.
Lucky for me, I don't have to unbox my Extreme which is waiting on a pallet in my garage for shipment. By pointing Roon at several locations on my LAN other than the local Extreme drives for automatic Roon backups, I can just grab a copy and update my current Roon lists.
Steve Z
Lucky for me, I don't have to unbox my Extreme which is waiting on a pallet in my garage for shipment. By pointing Roon at several locations on my LAN other than the local Extreme drives, I can just grab a copy and update my current Roon lists.
Steve Z
I use those myself exclusively aswell, incredibly convenient as I sometimes find myself changing Roon cores dozens of times a week. I actually had to verify if an “old fashioned” backup/restore was still necessary for “drive” based kind of playlists before posting! I could see Roon migrating these to an online based database at some point in time, that would be a nice feature.
That's the $64 dollar question. IMO the magic of a tube DAC is for my ears what floats my boat with the XDMI digital board. I do know that there were 3 members at my house this past weekend who, having heard this combination purchased a Horizon DAC from Lukasz and Fred
Reactions: ctydwn
Thanks for this Emile - time to have a rethink over my farad power supplies : )
