I thought James Brown was in the Soul business.
He was until he died and the preachers had to pray for his soul.
Well, that upping on money is sort of cheating because you just crossed the dividing line between bargain basement stuff, that put out by the manufacturer just to have a model in that price range, versus a serious effort to create a true value for money product. Which defeats the point of the exercise somewhat ...
Sort of obvious: no actives, also meaning no self powered bass drivers. The separate amp has to do all the grunt work ...Give me $10,500 to spend on actives and I'll smoke you.Hell, I'll let you have $500 speakers and a $20,000 amp.
Tim
Actually, you're probably right about the $500; maybe it's just me, but the prices of speakers over there seem to have climbed a bit of late. But I still believe I could do it with a $200 unit ...
Down here in Oz we, meaning quite a number of manufacturers, build very high quality speakers for the money: the typical UK efforts for the same money are somewhat rubbishy in comparison. Very solid carcases, big, meaty inductors for the crossovers, that sort of thing ...
Frank
I have been belittled a few times lately due to my choice of gear, which in essence revolves around the best speakers you can get and 'forget the rest' (which is why I am with Tim). Admittedly 500 does not quite cover what you need to go active
To be very broad, let's say there are three amorphous groups in audio...the 'source is everything' guys, you know Linn and Ivor stuff, there are the 'everything counts so we must spread the available funds evenly' guys, and the 'speakers only count' guys, with the possible extension of including the room. I am in the last camp..(are there more sub groups??)
The total budget - $10,500 is more than enough to go active. You could build and amplify a set of Orions for that money. Hell, you could probably have them built for you for that money. And I don't care what is amplifying them, I'd love to see Frank come up with a $500 pair of speakers that could do anything in a room with a pair of Orions other than embarrass themselves.
By the way, I'm assuming an un-tuned or anechoic room. Can't tune it for both sets of speakers. I guess Frank would be ok with that. Can't say I ever remember him spending a moments thought on the room, other than to say that it didn't matter.
Tim
So what would be an appropriate budget to set up this mythical sound off, and what would be each persons view of the percentage allocation of that budget?
Here's my take on the matter:
We hear what we hear through our speakers - which is pretty darned important - but not solely because of our speakers. As such, I've always been a huge proponant is getting the source right first. As is well evidenced by my setup, I would list it as SOURCE, SPEAKERS and lastly power/pre AMPS. It's worked well for me, but YMMV.
If someone has a crappy source in front of their awesome speakers, it will add a whole lot of soul.
Thanks for that insight, Tim. Just had a look at Stereophile's review of the same, and I think the Vienna's wouldn't do the trick for me, unless some significant tweaking was done: one problem for me is that they're too tall, signifcant effort would be required to stabilise them vertically; plus, they're rather reticent in the treble, "laid back" is the term used, which would need "work", perhaps ...And yes, I know the Orions would totally screw with Frank's big amp/small speakers test. I could go in another direction; give me the aforementioned $500 AVR with four amps bridged to a reasonably high-current 200 - 250 watt per channel stereo output. Now give me a pair of very high quality box speakers that present a reasonably easy, even load -- Vienna Acoustics' Beethoven Concert Grands will do. That set up would, I believe, kill any $500 speaker pair Frank can come up with, regardless of what he powers them with. And the system will come in $5k under budget.
Tim
IF you weren't allowed to do much internal tweaking of the gear I'd probably do 20% on speakers, 80% on amp. Probably, the more I could re-engineer the insides of all the gear the more it would settle down to equal portions for each area, because then you're worrying about paying for the intrinsic quality of the key component parts of each component.So what would be an appropriate budget to set up this mythical sound off, and what would be each persons view of the percentage allocation of that budget?
In the cheaper area, the well known Brit speakers, the ones starting with "M" always seemed poor value for money compared to our stuff ...Which os made speakers are you referring to?
Frank
Hello Terry
That’s tuff for me and I will expalin why. I simply could not afford the speakers I wanted so I went the DIY route and decided to clone designs I was interested in. The biggest issue with a DIY effort is your time. Hard to put a number on what that’s worth. Especially if are having fun doing it.
I fall into that camp and think the speakers are the most important part of the mix. That said I have been slowly improving my 2 channel system and it has been a fun experience doing so. I had several vintage preamps I was using that I got used for very little money. I ended up purchasing a modern preamp the Emotiva USP-1 and was very happy with it. I then decided to go the outboard DAC route and use my CD player and a universl DVD player as transposrts and compared the analog outputs with the output of the DAC. Well surprise surprise with the CD player very little if any difference. The DVD player however was another story. The analog section in the DAC was better sounding.
After those experiences I still consider the speakers the most important part of the mix but will be spending some more cash upgrading my amplifier shortly. For the mix I would but about 50%-60% into the speakers and the rest elsewhere.
Rob![]()
Frank
