That is an incredible lineup of Kondo amps! Thanks for the pictures and report, bonzo75.So managed to listen to the Feastrex single driver field coils permandur with a Kondo collector. Over a couple of days compared different Kondo amps. Baransu silver 300b, Kageki 2a3 (Souga is copper 2a3), and Ongaku and Gakuon mk1, all from Kondo San era. With M1000.
He also had some AN U.K. stuff but prefers Kondo.
He had the metronome Kalista playing through the Lampi Pacific. He used to own the AN 5.1 signature but preferred the golden gate and then moved to Pacific.
TT was AN TT2 with AN IO, he mostly listens digital.
Also heard some Marconi PX4 sound great on Lampi
Is that the only SET you have had in your system?I got my Audion SET 845 Black Shadow back. Its a Black Shadow 2 now. Its kind of noisy. It's pretty fat sounding. Extansion to bass is decent. Extension to highs are ok. Maybe more fair.
Compared to my Found Music Blade PP KT88. The Blade has way better upper extension. The Blade detail is light years better. The Blade bass is not as heavy. But its much tighter and natural. Blade does need more heft. The Dartzeel didn't have near.the detail of the Blade, but the bass was more fleshed out.
Audion gets put in here and there, but pulled out pretty quick. It sounds colored. Its.nice, but colored.
I see they are working on an 833 amp!Looking at getting an Apollo Audio 211.
Forgot to mention, the above Kondo guy also owned the Wavac SH 833 once.I see they are working on an 833 amp!
What is your result?Over a couple of days compared different Kondo amps. Baransu silver 300b, Kageki 2a3 (Souga is copper 2a3), and Ongaku and Gakuon mk1, all from Kondo San era.
Hi, I stopped using CDs and streaming for evaluation of speakers and amps long ago. I did out of interest compare his Marconi PX4s in the Lampi because I hadn't heard the Marconi PX4s before (though I had done a detailed compare of different Marconi PX25s with KR). I do love that Bach Cantata, and other cantatas in general though.That is an incredible lineup of Kondo amps! Thanks for the pictures and report, bonzo75.
Did you bring along the Bach cantatas disc listed as a reference at Zero Distortion, and if so, how did it fare on the field coil speakers? I don’t have a lot of experience with field coils and am curious to how they sort through complex counterpoint and timbres - thank you
Cool! Just a small point of clarification: Souga is silver, not copper. At least not mine, which is from c. 2015.I visited an audiophile to listen to the Feastrex single driver field coils permandur with a Kondo collector. Over a couple of days compared different Kondo amps. Baransu silver 300b, Kageki 2a3 (Souga is copper 2a3), and Ongaku and Gakuon mk1, all from Kondo San era. With M1000.
Isn’t Souga with silver transformers normally?I visited an audiophile to listen to the Feastrex single driver field coils permandur with a Kondo collector. Over a couple of days compared different Kondo amps. Baransu silver 300b, Kageki 2a3 (Souga is copper 2a3), and Ongaku and Gakuon mk1, all from Kondo San era. With M1000.
The one before Souga, the Neiro, was copper output transformers…Souga has always been silver.Cool! Just a small point of clarification: Souga is silver, not copper. At least not mine, which is from c. 2015.
Much better than permanent magnet drivers, is the answer!Did you bring along the Bach cantatas disc listed as a reference at Zero Distortion, and if so, how did it fare on the field coil speakers? I don’t have a lot of experience with field coils and am curious to how they sort through complex counterpoint and timbres - thank you
In all cases?Much better than permanent magnet drivers, is the answer!
The physics say yes. Constant magnetic flux, for one thing. Permanent magnets are Not a good way to make the best drivers. That’s clear.In all cases?
Thivian labs 211 mono amps no complicated construction, the iron used is beyond reproach. Disadvantage: the thing is heavy like lead. Pair 8.5k€The 211 are around $6k for a stereo version. The 833 is over $20k. They had them out at PAF. Looked nice.
