What tonearm(s) are people using with their Koetsu cartridges?
SME V12 on my SME 20/12 with a Koetsu Onyx Agate Platinum, recently retipped by Steve@VAS. Sounds great still.
How does the Onyx Agate Platinum differ from the "regular" Onyx Platinum?
Unfortunately they are far from being neutral just like other wood arms. They are more like instruments than tonearms. Wood is a ringing material especially on the frequencies we hear. If you like the sound of your tonearms none of the above really matters but they certainly have a significant sound signature.
Is this an empirical observation or a theoretical assumption?
Reviving this old thread as the OP, the wide assortment of tonearms people use with their Koetsu cartridges tells me there are no clear winners in this cartridge-tonearm match-up although the FR 64s/66s, Ikeda 407 and Glanz were mentioned most often.
I've narrowed my personal choices down to a Fidelity Research 66s and a Glanz MH-1200s. I find them both attractive, well-made and both have received excellent reports in the field. I wanted to ask if anyone has had the opportunity to compare an original Fidelity Research FR-66s to the Glanz MH-1200s tonearm specifically when used with a Koetsu? The FR-66s is of course the older arm and would possibly require some maintenance (bearings and wiring). For almost the same money, a new Glanz would be ready to go. A secondary question is how does the FR-66s compare with its little brother, the FR-64s which is about 1/3 the price?
Thanks in advance for your input.
In the end, the Glanz MH-1200S won out over the Fidelity Research FR-66S. The ease of buying a new off-the-shelf item was the deciding factor. In addition, one of the knocks against the Glanz had been its lack of azimuth adjustment, at least in the MH-124S. This shortcoming has been addressed in the 1200S as there is now a "tilt adjustment screw" which is located at the end of the arm tube and allows for fine azimuth tuning. Thanks to all who offered their experience and expertise.
Previously, some Glanz users have opted to substitute other headshells which have a built-in azimuth adjustment. The Arche headshell is frequently mentioned. Has anyone compared the performance of the stock Glanz headshell with the Arche or other brands of headshells?
Here are some shots of my new Glanz MH-1200S with the Koetsu Onyx on my TNT VI table. The difficult part was waiting for completion of the custom arm board, but it was worth the wait. The synergy between arm and cartridge is special. I am also using the upgraded DIN-RCA phono cable that comes with the MH-124S Premium tonearm.
Were you able to physically compare the two tonearms lem , or had you made up your mind after weighing up the factors and practicalities that you mention ?
I made up my mind after considering all the practicalities of buying a new arm over one that might be 40 years old with questionable condition of the wiring, bearings and overall cosmetics. I never compared them physically side by side. Richard Mak also gave the Glanz arm a very favorable review liking it better than his previous reference, the FR-66s (among Japanese arms). A number of people also reported the Glanz mated well with Koetsu. And it does.
Reactions: Argonaut
That’s interesting. The Glanz was on my short list when I was looking for a high mass arm to mate with a Koetsu. After being unsuccessful in locating a US distributor, I ended up buying a FR-64S from Japan and sending it to Richard Mak for a complete restoration. Richard replaced the bearings and installed new silver wiring as well as the regular cleaning and new grease. The arm looks and feels brand new. I can’t say anything about the sonic differences due to the restoration since I made other changes in the interim, but I can say the arm sounds very nice with a vintage Koetsu Black as well as a Benz LP.
You did exactly what I would’ve done, sending your Fidelity Reseach arm to Richard Mak for a complete restoration. As you know, he is quite the expert with the FR arms and even has a kit which replaces the FR-64 arm tube with a longer 66S-like tube. FYI, I purchased my Glanz tonearm from Japan.
Reactions: Salectric
Ekki,
Thanks for that very informative post. You have clearly studied this issue very carefully and how the mating of Koetsus with the various Schroder arms and headshells affects the sound. More often than not, Koetsus get (mis)characterized as having "sluggish bass, rolled off highs" as most people never get to hear them optimized with the proper arms.
I can vouch for that. I was using a Audionote Arm3 V2 which is 11.5g and had the something is missing feeling constantly. Did a even exchanged for a Fidelity Research fr64S and instantly I noticed a big difference.
Reactions: lem321
More body, more detail, Forgot to add better bass weight Everything from top to bottom was fuller
@SUPATRAC is there any advantage to mounting a Koetsu stone body on a 12” Blackbird vs a 9” ?
Other, perhaps, than the better inner grove tracking of the 12”?
The effective mass on both, I believe, can be tweaked with the external weight attachment.
Thanks!
Thanks!
Yes, all SUPATRAC arms come with a mass adaptor so you should be able to increase the arm's inertia to match the stiffness of a particular cartridge suspension. The limit to that is that longer arms and Nighthawks have enough mass that they may not be optimal with very high compliance cartridges, for example the famous Shures, which often track well at 1g. I would recommend a 9 inch Blackbird for those.
There's no practical upper limit to the mass/inertia you can add because the hoists are rated to 20lb and the performance bearing doesn't bear the arm mass at all. If you have a stiff old cartridge which you loved, but could never get it to track everything, you might find that making a SUPATRAC arm really heavy finally brings it under control for the first time.
As regards length/geometry, I don't think people often bother to ensure that their short arms present the same inertia to the cartridge as their longer arms, so most impressions of the differences between arm lengths are probably as much to do with inertia as anything else. There is interesting recent discussion at lencoheaven about the possible negative effects of offset/skating- forces, so it may be that the biggest reason to prefer longer arms is that they are straighter and require less anti-skate.
I'm guessing, as you can see, but it is not at all clear to me that the additional structural compromises of a longer arm are compensated by the minor improvement in geometric angle error.
My Koetsu Rosewood Signature cartridge is on a SME V and a friends Koetsu Rosewood is also on a SME V. I tried it on a SME IV. Vi and went back to the V after several days of listening.
Reactions: Joel27
