At least as respected as most others. And yes, you can read this in two waysI absolutely consider Roy to be a respected reviewer.
Excellent! Thanks for sharing all this. That's how it goes sometimes. Sounds like you are in for a treat with the Protos. Will your time with the DarTZeel and the Protos overlap such that you'll be able to play them head-to-head?
Yeah, I was thinking about that. About 130 lbs, right?hopefully or somewhat close at least, I will need to give space for Protos though and once it's up I'm not going to move it again, ever(!).... 65 kg might be lightweight for some of you, but I'm just getting used to the idea of it.![]()
BTW, perhaps you mentioned it, but what speakers are you going to be running the Protos into?Yeah, I was thinking about that. About 130 lbs, right?
I had help to bring it into my home but I was able to put in on my rack by myself...justAccording to Google 65 kg (including PSU) is like 143 lbs, either way probably too heavy to lift on my own.
I have a pair of Kroma Atelier Thais speakers from Spain.
NOT TRUE. Stop spreading lies.My best information (from several different sources) is that Dartzeel is out of business and has been for several months - although nobody seems to be talking about it and I have been unable to verify that this is indeed so. I would certainly want to clarify the situation before sinking any money into one of their products, new or used.
After his DartZeel comment he is most certainly Not a respected reviewer!I absolutely consider Roy to be a respected reviewer.
Hi full post is there in the thread. My quote indicates there is more before and after the part most relevant to what I was saying. I also see that the company has made a fulsome response.You've edited his quote. There was a 'to the best of my knowledge' part and a 'I haven't been able to confirm this despite trying' bit before and after the origianl quote.
Tell us how your really feel...Going back to Audio Note, I am sooo tired of the BS around that company. After stealing the name from Kondo, and 'copying' many of their amp designs, they then attacked the company with legal action. As for their products, I have owned the M3 Preamp, the Conquest Silver 300B Monos, the DAC 5 Special, and before any of that, built some of the copy kits (not great).
Sum up, the products are vastly overrated, unreliable, and IMO sound slow, coloured, midrangy, not accurate, and simply way overpriced for what you get.
On PQ, I don't need to go there, just have a dig around the web, you will see what I mean. Everything about the 'dark side' of high end audio. I am glad there are other really great companies out there to keep me interested in the hobby.
Enough said, but stay away is my opinion.
Difference? Integrity. Don't forget PQ is not a designer, he is a salesman.Tell us how your really feel...What about Kondo? Similar opinion? FWIW, I think a lot of the amplifier designs are quite different between Kondo and AN UK. I am not so sure that they stole designs...name obviously but designs no. One of the best Kondo amps comes even as a push-pull design (GahuOh 300B monos can be either PSET or PP) and Kondo never uses transformer coupling, which AN UK prefers for it's upper models.
Yes, fully aware. Most AN UK is designed by Andy Grove.Difference? Integrity. Don't forget PQ is not a designer, he is a salesman.
I'm looking at 3 integrated amplifiers which (depending on the case) I will be able to do little to no listening to.
Curious any comparative sonic impressions or characterizations any of you have of any combination of these amps:
- Audio Note UK Meishu Tonmeister (any current variant)
- Aries Cerat (Protos or Genus)
- darTZeel (MkI or MkII)
Thank you!
I have the same information here in France.My best information (from several different sources) is that Dartzeel is out of business and has been for several months - although nobody seems to be talking about it and I have been unable to verify that this is indeed so. I would certainly want to clarify the situation before sinking any money into one of their products, new or used.
I recently reviewed the Audio Note Tonmeister P3 and covered the Integrated. They're fine with 89dB speakers like Audio Note's own AN K/SPe which I own. Sure you can play louder with other amplifiers but it all depends on room size and volume level.I'm looking at 3 integrated amplifiers which (depending on the case) I will be able to do little to no listening to.
Thank you!
