my room is 16 by 23 by 9+ and they work great. FYI . thats a old shot but we also make smaller speakers FYIGobel are great but unfortunately they are too big for my space in my living room.
my room size is: 6.90m * 5.5m (37.95sqm), my celling height is 2.70m, my listening position is 3.5m from the main loudspeakers and the distance between the speakers is 2.40m
my main problem is the distance from the rear wall, currently I have only 30cm of distance so I need a speaker with sealed box like Magico or with front port like my Stenheim A5SE.
I’m still thinking that Gobel are overkill for my room.my room is 16 by 23 by 9+ and they work great. FYI . thats a old shot but we also make smaller speakers FYI![]()
I’ve heard both speakers. I listened to the Stenheim Reference 2 in a friend’s room with a 2.4m ceiling and didn’t like it, but I loved it in a different room with a 4m ceiling. Personally, I prefer the Zellaton Reference with three woofers; the version with two woofers doesn’t sound as balanced. The issue with Zellaton is its tweeter—it can sometimes sound harsh and forward, depending on the electronics. I’m also very familiar with CH electronics, and they tend to be on the bright side. That’s why I recommend you:
• Stick with the Alumine 5,
• Insist on hearing the Zellaton Reference in your own room,
• Or consider other s
my speakers located at my living room and I have no a dedicated audio room.
its your room and you need to do what you like however If you can take a listen and maybe you will change your mind. We do make them in any color you like as well . Look at a Marquis its damn good tooI’m still thinking that Gobel are overkill for my room.
I’m afraid that Stenheim Ultime Two need more distance for giving their best performances. I fear that in a 37sqm room the Ultime Two will simply overload the room
Ah, ok that makes more sense. Apologies, my mistake. Im guessing that whilst it might improve the sound, changing the room layout would be less conducive to domestic relations?Hi,
My room is not big, my listening area is only 3m * 5.5m so most of the big loudspeakers such as Gobel Divin Noblesse or Wilson Alexx are overkill and too big for my room.
Stenheim Alumine Five SE = Front port
Stenheim Reference Ultime = Rear Port
