Fact been smitten with my 3 SDFB.Just got my third SDFB, all with the best pig tail. They are great, easily beating the SR purples in there before. Just get one (or more!)
Unfortunately they only work in single fuse applications. Note too that a simple connector change on the device would eliminate the need for the “pigtail”.
In the current form of the SDFB and on some conditioner/regenerators. It would be nice having an option to avoid expanding the cable management challenge some face.But on its own it would take up more than one space on a conditioner/regenerator.
If the SDFB had a female IEC connector on the output side instead of a female AC connector you could plug it directly into the component without a "pigtail". You could also use it between power cord and an in line filter like the Lessloss Firewall 640 X or the Furutech Flux 50.In the current form of the SDFB and on some conditioner/regenerators. It would be nice having an option to avoid expanding the cable management challenge some face.
Hello Anyoldears,Just got my third SDFB, all with the best pig tail. They are great, easily beating the SR purples in there before. Just get one (or more!)
Yes thats right. At the moment I have a straight copper one in there, but I also have a rhodium and silver one still to try. These arent Veras ones, you can get them off ebay cheaply to see how they change the sound. https://www.ebay.co.uk/itm/204932285051 Someone also said a titanium one sounds great too https://www.ebay.co.uk/itm/226240041929Hello Anyoldears,
Have you connected a sdfb to the Innuos Next Gen Statement that I also have?
With what type of sluggo?
If so, with what results?
I'm interested because the SR fuses all blew in this machine and so I gave up on this type of tuning .
Thank you very much,Yes thats right. At the moment I have a straight copper one in there, but I also have a rhodium and silver one still to try. These arent Veras ones, you can get them off ebay cheaply to see how they change the sound. https://www.ebay.co.uk/itm/204932285051 Someone also said a titanium one sounds great too https://www.ebay.co.uk/itm/226240041929
As to the overall change, its an effect of more music coming through, like its coming through a fire hose rather than a hose pipe, everything just seems to be more full I guess, more detail, more presence. Apparently the effect is more marked the higher the current draw, so amps in particular are supposed to respond well although haven't tried them yet, and vice versa a low current device like the server is supposed to have the lesser effect. However despite this, I would recommend them, they are worth it even for the Innuos
Hello Anyoldears,
@MacF : Vous avez donc en série un ou deux firewall 640x et un sdfb sur la ligne d'alimentation de votre ampli ?Il se trouve que j'ai un Gold Note intégré, donc le SDFB se trouve entre un conditionneur/distributeur de puissance actif Synergistic Research et un câble d'alimentation Stellar LessLoss qui alimente le Gold Note.
Il y a 2 conditionneurs de puissance entropiques LessLoss Firewall 640x en série juste avant l'amplificateur. En fin de compte, les personnes sceptiques quant à l'installation du SDFB passent à côté de très bonnes séances d'écoute.
Par exemple, votre voiture est-elle équipée d'un mode Sport ? Lors d'une balade en campagne, sans appuyer plus fort sur l'accélérateur, passez en mode Sport et vous constaterez probablement une amélioration exaltante des performances. À mon avis, l'amélioration que le SDFB ajoute aux performances de ma chaîne stéréo est similaire et directement liée à l'installation de cet appareil sur le secteur.
