Xp20 - xp30
slowGEEZR
1,322
79
968
72
Colorado Springs, CO
Has anyone gone from the XP-20 preamp to the XP-30 preamp? If so, what improvements did you notice, if any? I'm so happy with the XP-20 that I wonder what can be improved. Thanks.
Bruce B
Apr 25, 2010
7,007
515
1,740
Snohomish, WA
www.pugetsoundstudios.com
Yeah... me too. Don't know whether just to get the 20 or go without eating for another month and get the 30.
slowGEEZR
1,322
79
968
72
Ha ha. Yeah, it's a delicious dilemma, though. I made the mistake of reading a review on the XP-30 and now I'm curious. I'll be sticking with the XP-20 for a long while, I'm sure. I think.
rockitman
7,097
414
1,210
Northern NY
Wish I could help. Prior to the XP-30, my main pre was the venerable Mark Levinson 380S. The only feature I liked better on the ML was volume control in .1 decible increments. The Pass's are 1 decible increments.
slowGEEZR
1,322
79
968
72
One downside to the XP-20 is that there are only two XLR inputs. I want three. I'm only using two sources now, my Mac Mini=>DAC and my turntable=>phono amp, but in the future I might add an Oppo 95 or some other multi format player and would then need another XLR input.
joeinid
1,543
12
400
NY
Wow!
Conclusion
In my opinion, there are very, very few systems which would not benefit from substituting the Pass Labs XP-30 for whatever current preamp is in use. Even if you already have an elite preamp in your system, you might be surprised by what you're missing. Very highly recommended, and at its current price you might even consider calling it a bargain compared to its competition, some of which are 50-100% more expensive.
jeromelang
439
66
935
The xp20 is a big improvement over my previous x2.5
The new one is quiet. Able to play it at a much lower vol level and still hear the important details.
But I just don't like the way the new design looks.....
The x looks way cooler.
PeterA
12,669
10,942
3,515
USA
I own the XP-20 and had the XP-30 in my system for about ten days. I have the XA160.5 amps, Magico Mini 2 speakers and SME table/arm with the Air Tight Supreme cartridge. I found the 30 to be slightly quieter and more extended both in the LF and HF. There is also slightly less distortion, so everything sounded cleaner and clearer. The 30 also sounded more evenly balanced. With the 30 in the system I noticed that the 20 has just a very slight emphasis on the upper bass/lower midrange region. Without this emphasis the 30 sounded more natural and midrange and treble details were easier to hear. Overall, I would say the 30 is a bit more refined, nuanced and real sounding. However, the 20 is still excellent, and for now I can't quite afford to step up to the 30. For others, the additional cost may be a small price to pay for the improvement in sonics.
still-one
1,633
150
1,220
Milford, Michigan
Thanks for the comments. I am considering another pre-amp and from the reviews the Xp-30 interests me. I would prefer a one box solution (that may be a play on words since the Soulution is being considered too) Prior to your post I was wondering what the additional box would give me if I chose the 30 over the 20.
Jim
wizard
856
2
16
wizard-highend.blogspot.com
XP-30 inside
Alps used here too - from the manual "XP-30 volume control is totally new and sonically unique. It’s measured performance - distortion, bandwidth, noise, and resolution is beyond reproach. It preserves the dynamics and detail of the music passing through it, and scales this performance over its 100 dB attenuation range."
The power switch looks like costing $5.
wizard
856
2
16
I've never used any Pass preamp, after reading the manual again - yes there is no power on/off switch.
It's looks like it's always on, so to turn it off one must unplug the AC power cable.
rockitman
7,097
414
1,210
Northern NY
That is correct. Pass recommends pre-amp power supllies remain on 24/7 for optimal performance.
