If you can't be part of the solution, then don't be part of the problem.
MylesBAstor Well-Known Member Apr 20, 2010 11,238 81 1,725 New York City Nov 23, 2012 #1 If you can't be part of the solution, then don't be part of the problem.
Mobiusman Well-Known Member May 24, 2010 705 564 1,655 Jersey Shore- waterside Nov 24, 2012 #2 If only it was that simple!!
Robh3606 Well-Known Member Aug 24, 2010 1,487 474 1,155 Destiny Nov 24, 2012 #3 How do you know which part you are? Rob
es347 VIP/Donor & WBF Founding Member Apr 20, 2010 1,578 35 1,620 Midwest fly over state.. Nov 24, 2012 #4 Robh3606 said: How do you know which part you are? Rob Click to expand... ..ask your wife
Shaffer New Member Nov 2, 2012 583 3 0 NYS Nov 24, 2012 #5 es347 said: ..ask your wife Click to expand... [rimshot!]
T TBone New Member Nov 15, 2012 1,237 1 0 Nov 24, 2012 #6 If you can't be part of the solution, then don't be part of the problem. Click to expand... Well, perhaps the solution is the problem. tb1
