Someone had brought up the fact that cables ONLY make a difference in a more resolving system. IF that is true, and I am now thinking that it definitely is, it would explain the many non-believers that are in the public.
Not so certain, a more revealing system may require a certain type cable, perhaps a "better" cable ... but even within what I consider mid-fi systems, I've heard certain cables make a distinct difference.
The trick with cables, is how they sonically integrate within a particular system. Again, like most dependencies, it's often a synergistic matter. Certain cables sound better within certain systems for reasons that are beyond explanation. One needs to find that proper mix. My system specifically prefers "lively" cables, and I always find it funny when I claim that I therefore prefer Cardas. Audiophiles will always challenge that notion, claiming that Cardas are generally not known to be the "lively" type. Well, they're indeed correct, however, I use Cardas Golden Hexlink 5C, a long discontinued cable that stands sonically apart from the general Cardas "house" sound.
One could in fact refine or maximize a system towards a specific cable by maximizing connection quality. In my system, I've exchanged the majority of female plugs to Cardas to exactly match the cable. This, in my experience, will maximize a cables influence on any particular system, but at the same time, it may make a system "cable" dependent.
Choice of Cables is one thing, but connection quality is way too often over-looked. I've attended far too many system demo's in which the components were judged, unknowingly to many listeners, solely based on questionable connections within the entire system. One time, I attended a demo of a very expensive system in which the banana plugs on some "famous" hi-end cable came apart from the speaker during the audition. When I investigated, the tolerances between cable and speaker connection were not ideal, to the point that time alone would allow them to vibrate loose. When I looked at the cable structure of the entire system, it became obvious why this system could never justify it's cost. Funny, that night I hinted to all that the relatively underachieving sound quality was partially a result of this systems cable choice and poor connection quality, but instead of dealing with that reality, they continued to exchange components based evaluations.
I immediately left with a sigh!
tb1
