TADs are certainly musical. But also very trnasparent. Another thing I really like about these speakers (all of them really), is that they show very clear any change you make upstream. Cables, for sure. But per instance also changing the playing mode (conversion) of the DAC. i can tell much easier and hear very clearly the diferences between the alternative conversion modes of the Esoteric D02. And so on. Also I noticed they change quite a lot with placment in the room. Per instance the CR1s bass and dynamics changed quite a lot depending of where you placed them.
The E1s, as said, I think they are giant killers... I have not listened to all the speakers out there of course. But if you compare them to speaker costing more, in my experience you need to spend aprox 3 times its cost to get better sound. And than it is a question of value.
How big is your room? I assume you have listened to the CR1s? They do have a lot of bass. I do not think the E1s has much more bass than the CR1s. Maybe the image is a bit larger in the case of the E1 and may have some more weight or majesty in the presentation, but the biggest diference among them I do not think is bass.
