SRA for Opus MM2
number95
384
7
250
I concur using better isolation below Transparent networks make a quite dramatic impact. Lower noise floor, better tone color, crystal clear highs and better bass articulation (not stronger but clearer bass tones with much less artifacts). I first tried wooden blocks to keep the networks at a bit higher to floor, the net impact was arguably better but with reservations. Then decided to put Acapella bases (were spare at the time) this time much better with no ifs no buts. Unfortunately used to order a pair of SRA for the networks before trying Acapella, hope they raise the bar or are at least at par with Acapella. I will update this thread after SRA getting delivered.
I just found time to update this. The impact of SRA bases is hard to believe. I have thought previously they would only make a subtle difference compared to Acapella bases, I was very wrong and SRA one more time has succeeded to surprise me. I have never thought Ref MM2 would be that good. With SRA under networks and Shunyata DF-SS elevetors, I bet my Ref MM2 may beat Opus MM2 without any cable elevetor plus network base in some areas. So, treatment of network with best possible effort is essential to get maximum of Transparent. Ok, if I need to mention a few sonic improvements, the most vital one is clarity, lack of noise, especially high frequencies are crystal clear, those improve transparency and resolution. Fatigue is completely gone, even the most complex musical passages are delivered w/o any stress or harshness. Bass texture is better and lower frequencies are stronger, helping to a more realistic and 3D presentation.
Frank750
821
1
928
I agree. When I used MIT cables, I placed Stillpoints under the network boxes with remarkable success. Results just as number95 suggests.
mcduman
126
4
325
i told you man. looking forward to hearing your system soon....
LL21
14,430
2,518
1,448
fantastic report. I have not isolated my RefXL MM2s from underneath (other than soft felt pads since the wood floor does flex a bit) but have found great benefit in using extra big Entreq Vibb Eaters on top of the network box. will try to give proper 'sandwich isolation' a try.
LL21
14,430
2,518
1,448
Hi Frank,
Which Stillpoints did you use? Or do i need to even ask? eek...Ultra 5s? ;)
number95
384
7
250
Frank750
821
1
928
Hi Frank,
Lloyd, you should no better than to ask, of course Ultra 5s. I tried some other types I had lying around but the Ultras worked best.
I even tried the Ultra 5s under the MIT boxes placed on Finite Elemente amp stands but it was overkill.
LL21
14,430
2,518
1,448
Yes, i should have known better indeed! OKAY - so lay it on me. Exactly how did you set these up? One Ultra 5 underneath in the midde of the network box? Or two per network?
Frank750
821
1
928
Actually, the Oracle MA-X SHD boxes are very large. I used 3 Ultra 5s per, 2 on the back end and one in the middle of the front end. Ridiculous I know. Long gone now along with the Stillpoints.
LL21
14,430
2,518
1,448
Whew! Well...something to consider given my own experiments have proven fruitful
jfrech
2,157
753
1,160
Austin
I guess I should not be surprised on this ! And I am going to have to find a way to try this also. Thank you for following up. Give me a few weeks/months, I'll try it soon !
blackhawk6969
3
Liverpool, England
I tried a similar experiment with pretty good results, so I have no doubt you hear improvements. In my case it was fairly subtle:
REF XL on a Vibraplane:
REF XL on a DIY bubble wrap:
Hi Peter,
Just wanted to say thank you, for posting your DIY bubble wrap pic. I tried the tweak underneath my Transparent MusicWave Ultra MM network boxes. The improvement aren't just subtle but clearly audible...increase in overall resolution and better tuneful bass
Many thanks
treitz3
Super Moderator
Staff member
Dec 25, 2011
5,480
1,010
1,320
Hello and good morning to you blackhawk6969. Please allow me to offer you a warm welcome to the WBF. Glad to have you aboard sir and thanks for sharing your observations.
Tom
blackhawk6969
3
Liverpool, England
Tom
Hi Tom,
Thank you Tom for accepting my registration to join your forum
There are a lot to learn from and share with audiophiles from around the world. I've already picked up a very valuable new tweak for free. Ha!
Keep it up
Kind regards
Wale
4,702
It is known but not proved that the mechanical properties of cables are responsible for a significant part of their "sound" . Changing the support of the cables will naturally make it sound different, but whether it is an improvement or a step back will depend on system and room mechanical properties. I have seen the Nordost Sort Kones or Finite Element ceraballs making significant improvements in systems, but sometimes they make it sound even worst. My listening room floor was built using "audiophile" techniques taken from the description of Winston Ma listening room and the cables spikes of the network boxes seat on soft wood - the effect of using mechanical isolation devices under the Opus networks is not significant.
Curiously I remember that Shunyata Orion speaker cables benefited a lot form using the cable elevators.
number95
384
7
250
I agree that impact of isolation should be more prominent in case of carpet. Regarding cable elevators, interestingly power cords also benefited in my case.
PeterA
12,669
10,942
3,515
USA
Hi Peter,
Many thanks
You are most welcome, blackhawk6969. I'm glad someone found a benefit to that contraption. It is fun when one can hear an audible improvement with such an inexpensive tweak.
LL21
14,430
2,518
1,448
Because my Zanden Transport is in for repair, i have 8 Ultra 5s just sitting around along with a number of HRS DPXII plates...
...so i went ahead and did the 'unthinkable' and put 2 each under the TA RefXL MM2 network boxes...and then eventually 3 under each network box. Definitively better, clearer, etc...everything people here have pretty much been saying. I would say it is not equivalent to an upgrade of 1 level up on TA, but it is noticeably better.
jfrech
2,157
753
1,160
Austin
Damn you guys...now I am going to have to try something soon :). Lloyd thanks for posting...a lot of feedback here saying it's better...from guys I trust...
LL21
14,430
2,518
1,448
I have Entreq vibb eaters on top from experiments many moons ago...but these Ultra 5s just went under tonite because they were sitting around while my Zanden is in for repair. Decided to stick a few things under and on top of the Oppo transport while i'm at it...all good. But the experiment with the network box did surprise me since i already had the big Vibb Eaters on top already.
BTW, i am giving an SC upgrade some serious consideration...
