Murray, what cables did you try with the CR1/911mk3 combo? Which did you find to work the best?
Hi,
Well - that is part of my problem down here in New Zealand - access to good cables is a very expensive and hit and miss affair. Basically though, I found the character of the 911 and Devialet very similar, so cables sounded similar on each. Yes I too have struggled forwardness of the CR-1s. On the one hand the clarity and detail is amazing, but on the other richness and warmth can be elusive with at least some amplifiers. I found this with both 911 and Devialet - but either the speakers are taming a bit after 6 months or my ears are getting used to them - they seem much less hard now than when they first arrived. It is still an interestign comparison to the Everests ..... both very good but quite different ......I'd probably enjoy either more if I wasn't aware what the other offers
I have Ridge Street Alethias bi-wire cables - they use largish rectangular silver conductors. The upper and lower conductors are different thicknesses and to my opinion that almost acts as a secondary cross-over - splitting the sound too much. However run in parallel they are the best cables I've tried here. But they are not forgiving and I'd say we're talking amplifier/cable/speaker all having the same uncompromising character. I've tried Kubala Sosna Expression cables here - they added warmth but seemed to do it at the penalty of the life that the speakers do so well - no prize. Recently I tried some Crystal-Speak Standard cables - these were closer to the Ridge Street cables but I thought were a step back relatively. I also tried some hefty Litz copper cables - lovely and warm but a very coppery sound - boring after a while. So I'm still using the RS cables - I guess maybe they are a pretty reasonable compromise. Having said that I've been tempted by this review
http://www.stereomojo.com/MGAUDIOCABLESREVIEW/MGAUDIOCABLESREVIEW.htm and will try these soon. Pretty big claims - we'll see....
Probably the simple issue is that I may not be dealing in the same strata of cables as the rest of the gear, but outside of in-home trials I don't see it reasonable to take $10k punts on cables with resale of not-a-lot
Anyway there is no doubt the cables can break these speakers so it's essential to find ones that suit.
BTW long ago I used to have (quite a few amps really) a Plinius SA250/4 - I suspect that would be a better match with the TADs than the 911 or Devialet - just a bit more focused on the mids.
Look forward to hearing other's expereince.
Murray
