RG58 Coax as audio cable
Light Dependant Resistor
34
2
238
Hi
RG58 coax the variety that has a silver proper braid, not strands of copper is well worthwhile trying as interconnect
It needs good end fittings. I presently use it for both interconnects, digital links and speaker cable, where i keep the
outer as a shield for both positive and negative leads.
Has anyone else discovered this relatively inexpensive cable for audio ?
ACHiPo
519
309
310
Pleasanton, CA
I used it for a sub cable and it worked fine. There are a lot of DIY cables using RG58.
DonH50
Jun 22, 2010
3,969
333
1,670
Monument, CO
A lot of audio cable is simply RG-59 or RG-6 as manufacturers can use it for audio and video. There are a lot of similar "flavors" of these cables with various levels of shielding and so forth.
I have used things like RG-62 in the past for its lower capacitance; probably doesn't really matter but I had a long'ish line to my TT at one time plus had high-Z tube preamp outputs so was counting every little bit...
