Paskinn, I'm still waiting for reliable, repeatable proof as well. But I agree with Mr. T ... I don't believe we will find it here. Frankly, after all these years, I doubt we will find it anywhere.
Hello, Ron! Good to see you still around.
Have you read this yet? http://dspace.mit.edu/bitstream/handle/1721.1/46225/41567257.pdf
Recently I wanted to compare a 1m XLR with a 8m XLR of the same type and brand at the output of the CD player. The difference in frequency response was less than 0.1 dB at 20 kHz due the the increase in capacity. As both cables were connected to the preamplifier it as a fast test and listeners did not know which was which. Curiously two of three listeners used the same words - the sound of the longer cable sounded less natural and more hifi.
I wonder how many metres of cable the signal had passed through in the studio.
And most important:
Foil/drain-shielded cable should be avoided in any installation that could be subject to significant levels of shield current at frequencies above 1 kHz.
Drain wires that carry a significant fraction of shield current should be avoided.
Until foil/drain cable is universally replaced by braid-shielded cable for permanent installation, it is critical that audio equipment have good immunity to differential mode signals above the audio spectrum.
The bandwidth of audio systems should be limited to the minimum required to achieve good amplitude and phase response within the audio spectrum. In no case should the bandwidth of an audio system exceed 200 kHz
SCIN is probably active at UHF, so circuit topologies should reject differential mode voltages to at least 1 GHz.
This is an old and tired argument, that does not ad anything new. It was used against high-end electronics - how many cheap ICs have the mixers?, power cables - how long are the power lines that connect your house to the power station, and so on. Audio signatures of components (including cables) are very complex and the way the brain understands them in stereo systems is a problem that can not be solved just using the Audio Precision analyzer and the superposition theorem. I needs a lot of audio and psychoacoustics knowledge.
One think I admire in cable designers is how some of them can create a cable, that independently of the very different systems, has some consistent sonic attributes. For those who know about cables, think about the Valhala or the Kubala Sosna Elation.
I'd still like to drill down into whether the best cable is no cable at all - if 1m sounds better than 8m (as was stated earlier), does 0m sound best of all? In many cases a person could connect his source to his ampifier with a 0.1-0.2m cable - which would automatically be cheaper than a longer cable, too.
Or is the very presence of the cable adding something to the signal e.g. effectively filtering interference, or re-synthesising missing information or performing some sort of 'aural exciter' role? In which case the cable might need some optimum length in order to do its work. If so, can the cable's beneficial characteristics be analysed and duplicated for less than the price of a car?
Here's some.
http://www.shunyata.com/
At first glance of the Shunyata page, I did not read of the existence of reliable, repeatable evidence to prove Shunyata cables can be distinguished from other cables WRT audibility. Did I miss it?
We can learn more about technical aspects...
The last thing I want is to get into the cable wars; but there has never, to my knowledge, been any 'proof' that decently specced cables sound different. Any of us can insist we hear differences (I think I hear differences) but every time there is a double blind test, we flunk it. We do ourselves no favours by loudly proclaiming 'facts' that aren't facts to the general observer. What's more, note that every cable seller has a different set of 'facts' to boost their claims.If the guys who make and sell cables can't even agree among themselves about the physics, why should anyone else?
As I said, I think cables can sound different ; what I don't believe is that we can offer any real,solid, evidence to back our beliefs. And individual claims about what they hear are valueless if those claims fail all public tests Belief in'cables'has more in common with religion than science. Which doesn't make it untrue, just impossible to prove. You either believe or you don't. I won't say more because I don't want to get entangled in one of thos interminable debates which have no truth conditions. Believe, or don't believe.
