That's an interesting perspective. I note that you are a commercial member and represent Lamm, but not Vitus. The Australian Distributor represents both Lamm and Vitus and has a very different view of Vitus. I must say I do too, and was impressed enough to buy a Vitus Class A amp.That means absolutely nothing! In this case "Class A" could mean anything but what it's supposed to be, used for marketing purposes only.
Firstly here is how Boulder describe their biasing for the Boulder 3050 -What does intelligent class A mean? Class A for a certain amount of watts then back to class AB when the going gets tough?
How many watts in class A? I could not find it in the documentation.
He was shooting using flash ... at lest on some ocasions. You can see the shades on some images.
You definately need a low f lenses + a camera with good sensor. The closeup of the Vox Olimpian logo I posted earlier, was also made in poor light conditions, with no flash or tripod (Sony RX-1 compact camera; full frame sensor and f/2.0 lenses).
The BIG Vitus on the Estelon was one of the best sound at the show.
In contemplating how best to answer you question XV, I reviewed Boulder's technical white paper for the Boulder 3050 which described Boulder's own form of intelligent Class A bias. Boulder describe their biasing for the 3050 as follows -
"Bias operation is Class A to full rated output power. A microprocessor controlled bias circuit continually monitors the voltage draw, current draw and load to adjust the bias current as necessary. If a musical transient requiring more bias current is detected, the microprocessor will raise the bias much faster than the audio signal to keep the amplifier operating within the Class A window. After the transient has passed, it will then gently lower the bias in a decreasing analog manner over a period of 28 seconds until another transient peak is detected. This has the benefit of keeping the 3050 operating in full Class A mode without the drawbacks of massive power consumption, excessive heat generation and the audible steps or “sliding” of other active bias management systems."
I suspect Vitus are doing a similar thing with the MP-S201, though to their own design. In regard to the Class A specs, I have attached the data sheet below fyi
Cheers,
Bodhi
Audioblazer I have since spoken to Hans and gained some insight into the biasing scheme for this amp, and went back and edited my OP. Therefore I would say your quote does not represent my current view.Do not know much abt amp technicality except what Vitus told me when we had dinner with him at Day 2. It seems the amp perform best when the temp is kept at about 55 centigrade. Friendly guy. I m sure if u email him , he would be more than willing to explain to you about the amp
