Magico S5
rbbert
3,820
239
1,000
Reno, NV
It's only been a couple of weeks since his last posts; I wouldn't assume he won't be back...
Garth
299
Well I guess we'll have to agree to disagree on that subject. I think while you might come to a different conclusion using digital, it wouldn't be the right conclusion.
The video interview you did was very well done that is a lot harder to do than it looks. Still not a Magico fan maybe I have not heard the right set up yet. Anyway good job.
cannata
510
64
263
Italy
mep too. my guess is it was related to that spat about calling mep a whipping boy, etc. where there were some severe warnings.
I must have missed all that… That is a shame. Myles review of the S5 is superb, both in writing and in this video. I found his posts generally even and courteous.
rbbert
3,820
239
1,000
Reno, NV
If by "generally" you mean more than half the time that's probably an accurate statement. He's still active on other forums with a large overlap in membership with this one, sometimes it's hard for me to notice who's posting what where (except poor Northstar, who manages to get himself banned everywhere :(
pelo911
102
Houston , Texas - USA
Hi
i have Focal Maestro
Vitus SM-101 Mono
Pass XP-10 Pre
regular PC with Luxman DA-06 DAC
i don't like the sound so much
weak bass (i thought the Maestro should have great bass)
i thought maybe to replace them with Magico S5 or Q5
anyone here had a chance to compare the Maestro with Magico?
someone told me the Maestro need Devialet 200 or 400
because the Vitus only 100W per channel , and the Maestro need more power to drive well.
i'm not sure.
Thanks
dafos
306
Strange, I've auditioned the Maestros in my room and have heard it countless times at the dealer showroom and if anything, I feel that the Maestros have a bit too much bass, certainly more than what the Q5 or S5 delivers. Further, the way these speakers present bass is quite different, with the Maestros bass somewhat ripe and loose vs the Magico's tight and taut presentation. In short, if more bass is what you're after, the Magicos may not be the answer. Maybe you should climb the Focal ladder up to the Stella.
Further, while The vitus are great amps, 100w may not be enough for the maestro, certainly way short of what is needed to drive the S5 or the even more inefficient Q5 properly. For any of these speakers, I'd start with at least 200 watts.
pelo911
102
i heard the S3 at the CES show , like them very much
with my Maestro , maybe something is wrong with my setup
or the Vitus not have enough power to drive them , this is why the lack of bass ?
what Amp usually drive the S5 or Maestro?
Stella using Magnetic bass driver , it's easier to drive then the Maestro.
MadFloyd
775
1,700
Mass
Do you have a photo of your system so we can see the relationship between the speakers and the room?
bvdiman
69
10
240
pelo911, if recalled correctly I have seen pics of your system elsewhere.
If it is still same, problem mainly lies with your room and set-up positioning, imo.
No matter which speakers you ended up with, it will be a waste of money until you have the former addressed first.
Do post latest pics so guys here can help suggest more meaningful solutions.
scouter
241
4
Wrightsville Beach, NC
Spectral 260 will drive the Magico S5 nicely. Also, I've heard the big Plinius drive the Q3 with aplomb.
pelo911
102
new house
stereo
407
4
143
I disagree with you. His Vitus amp is way more than enough to drive the S5 or Q7 -I have extensive experience listening to this combo in a very big room. Even the 25W A-class integrated Vitus amp drivers the S5 without any problems. Keep in mind that nominal power doesn't mean much. What matters most is impulse power, current capacity...
With my Q1, 25W is not enough as with all 2 ways they have a lower efficiency. 100W Vitus is perfect match for it. With Q5, you are better off with 300W.
Maestro has a rife and mushy bass (not tight and controlled enough for me). If he is not hearing enough bass, most probable it is a room mode issue, not electronics. First thing I would do is to take measurements before spending a fortune in new equipment. Then I would replace the speakers ;-)
Orb
3,010
2
Pelo,
I see the problem in the photo...
You need to sit between the speakers and not to one side :D
Only joking, btw I love the curved staircase (what shows but to my mind they are stylish).
Cheers
Orb
dafos
306
Pelo, try spreading your speakers as far as is domestically or aesthetically possible. Not only will your bass improve as you move your speakers nearer to the corners, your soundstage will also open up.
MadFloyd
775
1,700
Mass
+1
pelo911
102
Pelo,
Cheers
Orb
it's not me , it's my Brother :)
when i'm watching a movie , i'm getting amazing sound !
bass and dynamic , really great !
i watch "Neighbors" yesterday , sound like i have a very big sub-woofer.
i'm not sure what is the problem with Music.
