Living Presence
DDB
18
...The view from those two window doors?
Beyond those curtains is a breathtaking panorama indeed.
Clear view to the Bavarian Alps in close range ..... this listening room is at 2500 feet altitude and surrounded by nature to match the sound.
ALF
531
244
955
Southwest
"There are differences"...Syntax
Okay...it helps knowing where you are going before you get started.
The typical audiophile's pathway, of starting with a part and moving towards a whole, is fraught with potential missteps and a tendency of a premature commitment where one can fall under the spell of believing in "Product Placements" and/or falling into "Group Think." There is nothing wrong with this approach, everyone has to start somewhere; however, IMHO I believe that there can be something to gained from stepping back and therefore reverse engineering the process and finding differences that work from the appropriate endpoint. Hence, when moving from the whole to the part orientation, one will be more likely to follow a conduit that is better-in-kind.
Cheers!
ALF
Syntax
259
307
970
At The Dark Side
That all in modern times, with the best of modern equipment at hand and with lots of funds in the back.
It still doesn't qualify for any list of good sounding concert halls.
You find that all over...
Jimmy Page (Led Zeppelin) said... when they went to Headley Grange (a House) they had absolutely no Plan where to place their Instruments or where they should do the recordings finally. They found a place by accident because John Bonham got new drums, the technicians placed it somewhere in the house and he started to play for a test...and the sound was so phenomenal that they made all recordings in that room... and other Bands followed...
NorthStar
24,305
1,323
435
Vancouver Island, B.C. Canada
...The view from the front window and window door?
- Enhancement (from the view).
- Non-linear (mountains).
- Moving (the front window door can be opened).
- Whole (room, loudspeakers, plants, albums playing, and the view of course).
- Part (of the entire synergy).
:b
I edited my post (above quote above yours). :b
ALF
531
244
955
Southwest
Getting Perspective
Listening Room...where the air and the mains are clean.
One of the goals is to eliminate the boundaries and fall simply, maybe even hopelessly, into the music.
Everything else is a "tool" to facilitate the journey, nothing more...no magic machines, product placements, or fan groups will open the door to deliver you where you really need to be.
Cheers!
ALF
NorthStar
24,305
1,323
435
Cheers!
ALF
Ha! Now we got it! :b
Syntax
259
307
970
At The Dark Side
Ikeda Cartridge
Stunning ability to accelerate.
Excels at textural production in a large authoritative sonic picture with musical flow and a clean, ultrafast top end. No Cantilver, needs an Arm with top bearing, Energy transfer is key ...
The right Cartridge for the ruthless Audiophile, he can spend endless time for adjustments ...:D
But when done right, it is an amazing unit from the audiophile prime time in Japan.
Output voltage: 0.15mV (5cm/sec.45' 1kHz)
Load impedance: 1.0?
Syntax
259
307
970
At The Dark Side
This cartridge moves a lot of energy into the Arm. Good energy transfer, rigid bearing, good Geometry is the key for a remarkable Performance.
Syntax
259
307
970
At The Dark Side
Thanks for your compliments :)
Here are 2 from a System I listened to last year. Impressions...
my favorite one is the one from those Japanese Turntables...
Syntax
259
307
970
At The Dark Side
Yes, Wilson, I think it is called 'Alexandria'
Their location is Southern Texas ...
cjfrbw
1,355
1,730
Pleasanton, CA
Alexandria and Lamm ML3's, also in residence at our own oneobgyn's.
Syntax
259
307
970
At The Dark Side
Yes. These are very heavy and made in the 80's.
Record Cleaning Machine
The best investment the analog Audiophile can do. There are different Designs out there, they are different in speed, comfort and - of course - cleaning results.
Not the fastest but the best result (by far) is the point nozzle Design. Developed from Keith Monks in GB.
You will find in the Internet endless discussions about the "best" Cleaning fluid but the secret - at the end of day - is not the fluid, the secret is to get it out of the grooves. Specially when you clean a few in a row...
The solution for the serious User.
MylesBAstor
81
1,725
New York City
I'd say you underestimate the importance of the RCM. The machine's ability to remove the last vestiges of the fluid varies considerably. And remember you're fighting physics as it becomes increasingly harder and harder to remove the last traces of the fluid in the grooves because of hydrostatic effects (surface tension increases). That's why the amount of vacuum (which must be always balanced against damaging the LP) is very important in my book.
And yes, it's what's left that is important :) Talked about that 15 or more years ago when did a RCF survey for Sounds Like magazine (you can see parts of it I think on Fremer's website -- or else I think it's on the web somewhere). And fluids have improved greatly since then (as have our system's resolution). But once again the newest enzyme based RCF formulas have shown us that we can do even better in cleaning the record, esp. in reducing surface noise and those annoying pops.
