Instead of making general statements, why don't you provide a list of so-called high-current amps that "poop out" when driving a "tough load." After you provide a list of those amps, list the speakers that were used with them that caused them to "poop out."
MEP,
Simple example: MBL 101. But regardless of the speaker, my question is general: is there an indicator, a sign, or a spec that could hint that an amplifier is "high current".
Interesting comment on switch-mode power supplies. In the designs I work with, SMPS' are the "go-to" architecture for very high current delivery. Linear designs are too slow, far too bulky, and waste far too much energy. And our noise specs are extremely stringent over a very wide bandwidth. But, SMPS' are perceived as "worse" and "cheap" in the audio realm by virtually everyone I have spoken with about them.
I agree with Mark about looking for amps that double power with halving of impedance, and cite the ability to drive very low-impedance loads. Bridged designs will struggle much more to drive low-impedance loads by their very nature.
I was referring to size only. I only mentioned SMPS because they are not big. I didn't say they don't deliver current. I've had a couple of class D amps with SMPS recently and they deliver unlimited current.
Sorry, must have read more into this than you meant:
"Usually it's the amplifiers that are really big with massive transformers that can really deliver the current, as long as it's not powered by SMPS."
Now I am confused by what you did actually mean, help? Maybe the opposite of what I thought, that with SMPS there are no big transformers so does not fit the "usually big transformers" part? That makes more sense now that I read it back.
Long week... - Don
Since gobs of power are typically not required all the time and are usually only needed for peaks, I usually look at the capacitance storage figures (in micro farads) as a rough guide on top of "doubling down".
Pretty much Lloyd. It's partially why, say, some 100wpc amps can run out of gas slower than others of the same rated RMS wattage.
MEP,
The MBL101 is not that hard to drive! A 200 - watt tube amp will be plenty of power in most rooms. The real issue with the 101 is not whether the amp can make the power, but if it will throttle its power back properly when encountering that 8 ohm load in the upper midrange. If not, the result will be brightness.
More about that at this link: http://www.atma-sphere.com/Resources/Paradigms_in_Amplifier_Design.php
A secondary issue is whether its a good idea to demand high current out of an amplifier even if its capable of it. The evidence of measurements is that it is not. If you look at the specs of any amplifier you will see that the distortion of the amplifier while driving 4 ohms is always higher than that when it is driving 8 ohms. The distortion drops further into 16 ohms.
So the question really is whether that increase of distortion is significant, as in- can you hear it? The answer is, yes, you can hear it, as the distortion product is mostly higher ordered harmonics, to which the ear is keyed to detect the sound pressure level. IOW we are more sensitive to higher ordered harmonics in a sound than almost anything else, due to the fact that its actually really important to our survival.
The bottom line is if you are making an investment in an amplifier for home audio purposes, that investment dollar will be best served by a loudspeaker of higher impedance, all other things being equal, entirely on account of how human hearing/perceptual rules work (which does not vary from human to human, unlike taste). If you are more concerned about sound pressure, where sound quality is secondary, there is a weak (3db) argument for four ohms over 8 ohms.
