Yes well I think the Valhalla can fall into the same classification as the Transparent. Hey Steve, how come you didn't go to the Odin?
how do you spell D-I-V-O-R-C-E
FWIW I am quite happy with my Valhalla.
Here is what I use made by Precision Audio Products
here is their explanation as to how it works. Snake oil, science or a bit of both
The Reasoning
Precision Audio Products provides the following explanation on how and why cable elevators work:
Cables come in contact with a wide variety of flooring surfaces. Each can have a different effect on cable behavior. By elevating cables off the floor you eliminate static charge and you lower capacitance. The net effect is lower noise and increased dynamics. Another factor is the dampening of the natural modulation inherent to all cable. That is an electrical signal passing through a conductor (cabling) produces a desirable mechanical resonance that is dampened when placed on the floor. This also constricts dynamics and low-level detail. Placing cables in free space would be ideal.
Here is what I say about cable lifters. In certain setups, they do make the installation look more clean which is always desirable. They also make you look like a really serious audiophile to non-audiophiles because they can see you have left no stone unturned in your quest to bring out the best in your system.
Mark
Gregadd
They can't isolate the cables from the floor vibrations: they are made of porcelain, they will simply transmit these vibrations to the cables
Frantz
They make absolutely no difference other than being able to tidy up your runs of cables. I've used cable elevators for at least the past 10 years
Available at your local home supply store or online at Amazon.comClothes pins (remember those) work great. Just snap on the cable and the other end holds them off the floor. Paint them any color you like.
I would like someone to come up with an easy to use cable arrangement device to help the spaghetti behind my equipment rack. With power cords and interconnect between two racks and 15 pieces of equipment, I have yet to find a way to keep it organized (other than having all custom made cable lengths made).
Interesting analogy Greg, coming from another who has benefitted from those medicines.
Dan
Hi
My experience is at the oposite spectrum for the mpingo ... I have tried the mpingo and they have cosistantly done nothing in any system I have seen or not seen them ... The Room Tunes Pillows are a diferent thing , they make a slight not defintive, not sure difference in the systems, I have heard them in ... I would not bet anything on the efectt I thought they they had on the sound ...
Cable lifters are one of those things the audiophile world goes abuzz about for a while .... and dissipate as they should because their effectivenes is nonexistent ... High End Audio is littered with such products ...
