We hear differences between spades and banana plugs easily.
I think I have only heard differences when a connection was very poor. The output impedance of the amp and speaker's impedance usually swamps the wire, let alone the connector. In practice I am not sure the difference between a few milliohms and a few tens of milliohms is audible, at least to me (ears of clay). Unless you are driving some very low-Z speakers (Apogee, some ESLs and conventional designs) it's hard to imagine it making a difference?
We can hear differences in how tight the spades are as well (its not BS)- especially if the speaker is lower impedance, not so much when the speaker is higher impedance like 16 ohms. This is because as amps go, our amps have a somewhat higher output impedance and things like that suddenly matter. When working with solid state many of these differences seem to vanish.
That seems counter intuitive. If you have a higher output impedance to begin with, then it seems like you would have more wiggle room on wire and connector impedance without changing the sound (smaller impact of net Zout, or damping factor if you prefer). With a big SS amp the difference would be much larger in terms of change in impedance seen by the speaker. A damping factor of 100 (SS) implies 80 milliohms driving impedance; DF = 10 (tube) means 0.8 ohms. If you add 10 or 20 milliohms the impact should be less with the tube amp? This does not take into account dynamic impedance and the frequency dependence of the output impedance, natch.
I know some amp designs used to run a feedback wire from the speaker terminal to compensate line loss and keep the impedance low at the speaker.
The Cardas posts are usually raw copper. Its not a problem so long as the connection is in fact tight- it will stay oxygen free. If its loose, corrosion will slowly degrade the connection.
I had pure copper connectors on my old Counterpoint. I used heat shrink (no real help, couldn't get a tight seal), epoxy (now good luck getting them off), caulk (still not a great seal), and finally just a clear lacquer coating to seal them. I would not willing go back, too much work to keep them from oxidizing, though a good tight connection should be hermetic. I found Cu soft enough to work loose over a fairly short time (months) and had to keep tightening them down.
I always appreciate your posts Atmasphere, please accept my comments as questioning and not challenging. I am curious about the output impedance, must be overlooking something (what I get for fly-by posting on lunch break!) - Don
