This is a common theme around here, and one we have very recently touched on in the epic Objectivist/Subjectivist thread. I'm not really even doubting that this happens, really, I'm just hoping, expecting, that it is much less prevalent acceptable than I think I'm hearing. It has, several times, been used as an answer to how speakers can measure the same and sound dramatically different. I added the "dramatically" myself, because by the time you listen to one amp, take it out of the system, hook up the other amp, calibrate the volume to match the first amp and listen again, any difference you're going to be certain of hearing is, by necessity, going to be a serious one. Given that, and the assumptions that a) we're talking about well-designed solid state amps that are not deliberately colored in FR, and b) we're talking about well-designed speakers that are not wildly esoteric fringe products with very limited compatibility, a few questions:
Aren't quality amplifiers specifically engineered to avoid this problem?
Aren't many (most?) high-end amplifiers, in fact, over-engineered so they will be able to drive the widely variable loads of most high-end speakers?
If a variation in speaker load audibly changes an amplifier's output, would that change in the amp's performance not be measurable?
And if this condition is as common as we seem to think it is, shouldn't amp manufacturers recommend compatible speakers; shouldn't speaker manufacturers recommend compatible amps? Or at least warn us off of bad matches?
Wouldn't a BIG selling point for amp makers be an amp that is able to drive any reasonable load without veering off course, without compromise in performance? Isn't it?
And just to be sure I understand, you guys are saying that, if you switch from, say, Magicos to Revels, the audible output of your Bryston or Krell or even your Emotiva is going to change? And you find this acceptable?
Tim
Tim
