Typical Aesthetix they have the slowest repair/upgrade service i have experienced, and products that constantly break ! A bad combination ! I am at the point where i almost don't bother having it repaired again, it's just going to break again soon after. My Io has been sitting waiting in boxes for over six months now, maybe i should drive it to the dump instead of repair ?Does anyone know of a repair service other than Aesthetix for their equipment? My Io has been at the factory for three months waiting on what should be a minor repair without much communication from them.
Thanks
No i have no patience anymore, last time it broke, the importer gave up on sending it back to America for a third time and had a local very talented repair guy do the work in Sweden, it was still under warranty back then ! Aesthetix did not want to give the importer the diagrams, he had to make his own !
Hi Lagonda,No i have no patience anymore, last time it broke, the importer gave up on sending it back to America for a third time and had a local very talented repair guy do the work in Sweden, it was still under warranty back then ! Aesthetix did not want to give the importer the diagrams, he had to make his own !
Hear ! Hear !when I had the Aesthetix Io volume back around 2000, I had to buy another one as spare when the other was out for repair
unstable, unpredictable, shitty mechanics and even worse support
Ciao Johan K ciao Lagonda è possibile avere l’indirizzo mail del signor Björn Haglund poiché I also had the power supply of my signature io went up in smoke and I have had my beloved signature io repaired for a long time by the engineer Alberto Ingoglia of Aurion audio, a disaster occurred inside the power supply, but not having of the schematics and values of the components it is not possible to fix it, of course I wrote to aesthetix but they seem to keep their secrets more closely guarded than the state secret on the assassination of Kennedy. So much was the desire to go back to listening to my beloved vinyl records that I bought an allnic h7000v. Can you give me a hand, I'm also in Europe and in particular in Italy and I have no desire to ship everything to the United States because in addition to the cost of shipping, given the considerable weight that would be close to a thousand euros round trip, I run the risk that on return the customs will apply a tax equal to the value of the signature (it has already happened to an acquaintance of mine who first had to pay and that after two years he managed to get the customs tax returned), it might as well be that with the same money I would buy a koetsu red signature cartridge.Ciao Lagonda,
Tu ed io siamo ancora molto fortunati ad avere il signor Björn Haglund, per riparare e riparare le nostre cose. Non ci sono molti ragazzi in giro con la conoscenza che quest'uomo possiede.
Mi dispiace molto per entrambi voi ragazzi che avete problemi con il vostro Aesthetix. Per il prezzo di quelle macchine, i tempi di assistenza e riparazione dovrebbero essere ugualmente alti, si può pensare. Cosa è successo alla responsabilità dei produttori hi-fi di fascia alta in questi giorni? Mi sento frustrato solo a pensarci.
Spero che alla fine vada bene per entrambi ragazzi, Lagonda e Pwolo.
/Jk
Hi Massimo66,Ciao Johan K ciao Lagonda è possibile avere l’indirizzo mail del signor Björn Haglund poiché I also had the power supply of my signature io went up in smoke and I have had my beloved signature io repaired for a long time by the engineer Alberto Ingoglia of Aurion audio, a disaster occurred inside the power supply, but not having of the schematics and values of the components it is not possible to fix it, of course I wrote to aesthetix but they seem to keep their secrets more closely guarded than the state secret on the assassination of Kennedy. So much was the desire to go back to listening to my beloved vinyl records that I bought an allnic h7000v. Can you give me a hand, I'm also in Europe and in particular in Italy and I have no desire to ship everything to the United States because in addition to the cost of shipping, given the considerable weight that would be close to a thousand euros round trip, I run the risk that on return the customs will apply a tax equal to the value of the signature (it has already happened to an acquaintance of mine who first had to pay and that after two years he managed to get the customs tax returned), it might as well be that with the same money I would buy a koetsu red signature cartridge.
grazie comunque forse in germania c'è un centro assistenza pubblicizzato su audio markt, credo fosse un ex centro assistenza autorizzato aesthetix. speriamo di sì mentre mi godo il mio nuovo allnic 7000v. il tecnico audio aurion mi ha spiegato il problema più grande è che non avendo i valori corretti dei componenti, anche se vai per tentativi ogni volta che lo provi devi rimontare tutto il dispositivo e perdere un sacco di tempo, poi se hai dei valori sbagliati devi smontare tutta la piastra e perdere ancora un sacco di tempo e il lavoro diventa antieconomico per il riparatore che poi ti deve fatturare un sacco di soldi. Penso che il comportamento dell'aesthetix sia folle, se da un lato protegge a spada tratta la proprietà intellettuale, dall'altro sta distruggendo la reputazione di un oggetto di culto. Per non parlare di tutti i problemi riscontrati dai proprietari di RHEA (io l'ho avuto circa 9 anni fa), se lo guardi male si offende e si autorompe da solo. E pensare che prima dell'IO aveva una bat vk 10 se... una specie di corazzata inaffondabile.Ciao Massimo66,
Mi dispiace molto per il tuo travagliato Aestheix IO. Sembra che tu non sia il solo ad avere questo tipo di seri problemi con lo stadio phono IO. Ancora peggio è che Aesthetix non si prende le proprie responsabilità più seriamente.
Ora…
Björn Haglund è un riparatore molto speciale, con una conoscenza senza paragoni. Tuttavia... ha 76 anni e l'ultima volta che ho parlato con lui, ha detto che la sua salute non era più al massimo e che aveva concluso la sua attività di riparazione. Devo rispettarlo. Detto questo, non sarò in grado di aiutarti, anche se lo vorrei. Sono molto dispiaciuto per questo, e posso solo consigliarti di trovare il miglior riparatore elettronico in Italia per aiutarti a riparare il tuo stadio fono.
Vi auguro buona fortuna.
Cordiali saluti
/ Giovanni
the Allnic is very good, please also try the KR rectifier in it instead of the stock rectiSo much was the desire to go back to listening to my beloved vinyl records that I bought an allnic h7000v.
Hi Ked,the Allnic is very good, please also try the KR rectifier in it instead of the stock recti
