I remember (maybe misremember since it was 30+ years ago) that people did something similar with the old Magnepan or Magneplanar speakers, which have the tweeter ribbon running up and down one side of the panel. They reversed the two panels (L vs. R) so that the tweeters were on the outside instead of on the inside to broaden the soundstage. Some old timer please correct me if my memory is wrong here.
Larry
Larry
I think I meant to write the tweeter array driver. Will change
Ked,
IMHO it would be great to have all the threads concerning your blog in a common zone in WBF - perhaps a ZeroDistortion WBF section. Also I would suggest that you include one or two photos in the first post of each thread - people will immediately know what type of system is being debated and probably you will get more visits!
Ked,
Ked,
Ked,
I suggested that to Ked last week and he was reluctant. I agree with you Micro
There is a good blog feature here
I suggested the same thing to Kedar yesterday.
Larry
We usually tend to position the tweeters away from the side walls, for less reflections. Most designs are constructed that way. My own speakers are.
I don't remember if I ever tried to reverse them...but I'm wide open in experimenting.
Today with acoustical room treatments on the side walls the design philosophy has changed for the more versatility.
______
