I’m confused what is the tube no. is 6H6P or 6N6P or they 2 different tubes .
Thanks in advance ,
Tdh888
It was a little dim, ie reduced treble energy, in the first few hours, bass was too strong and not very controlled. Now it is back to normal. The sound is obviously different from 6H30DR, it is softer and more mellow. I think every ARC user should at least have some 6H6P's with them for a change.
Tima i would not call it in Ref6 “softer and mellow”. I find the preamp after installing those just much more musical/natural overall, where speed, dynamics, extensions, bass precision and control are all there.Thanks for your report. Could you please say more about the sonic differences between the 6H30 and the 6N6P in your Ref 10. Do you have a preference?
Without having tried the 6N6P, from the descriptions here thus far, I can imagine "softer and more mellow" having a more preferred effect on the Ref 6 / 6SE which is a bit more forward/bolder than the Ref 10. Conjecture only.
Now 6N6P are installed in the power supply unit of my Ref 10 and Ref Phono 10, 6H30DR are used in the main unit. I find this gives the best of both world.
I'm a bit lost regarding the 6550 in correlation with 6n6p? May you pls explain. Thanks!I do like the original SED Winged-C 6550, with which the unit was voiced originally.
Sure. I did not mean to correlate it with the 6N6P per se, which I have not tried. Just commenting on tubes in ARC power supply since @TLi mentioned them. The original Winged-Cs haven't been made since ... I think 2011, but offer better control than the current ARC stock 6550. More recent Winged-C is not recommended.
As for rolling 6550 in ARC power supply, I tried around 10 different types of 6550. It has a very large impact on the sound.
I now use two pairs of Tung Sol 6550 black plate in my two ARC’s. Once you listen to Tung Sol black plate, there is no turning back. Tubes in the old days, like 6N6P, have simpler design and less inner components but they often sound better. That’s why the original 6550 by Tung Sol is still the best.
I use the original Tung Sol in the late 50's and early 60's. Black plate is only found in the original ones. All later versions have grey plates with or without holes. I have tried them all.Sure, NOS tubes of all sorts give the opportunity to modify sound. I'm familiar with the different 6550s. Some people like the GE6550A. I have some of those but don't use them. The original Tungsol 6550 black plate is NOS and quite expensive if they can be found. There is a newer version made by Reflektor in Russia. Which are you using?
Even for black plate, they have three versions with different number of getters. I found the most early version has the best sound. I posted a detailed report in local Chinese forum on all these 6550, you can have a look.
https://www.hiendy.com/hififorum/forum.php?mod=viewthread&tid=91460
The 6H30 next to 6550 is for power supply. That one tube has the effect as all other 6H30 or 6H6P.Which is that one? I changed all except one...the one near 6550
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
