No, I am not underestimating it. I have now burned-in 16 KT150's in cj LP275's and they also sound terrific in these amplifiers - much improved bass! My supposition is that the great difference between old and improved Jadis's is due to the KT150 and the new coupling capacitors from the SCR factory. But I have yet to confirm (or deny...) it.
OK, I spell it - remove the tubes and play the CD at an high level in the volume control of the preamplifier. The coupling capacitors will get the signal in full and burn-in, as their load are the the output tube grid resistors , still present in the circuit, and your tubes, speakers and ears will be safe meanwhile.
The idea of capacitor burn-in is exciting them with electrical signals, not heating them!
I seem unable to hear a difference between Solen and SCR teflons. The analogy with Blackgate is inappropriate: those were manufactured by Rubycon under license and used a completely different technology to anything Rubycon ever produced.
It is interesting if Jadis do not burn-in the caps before assembly. They might.
Probably. Most manufacturers include this general warning, but mainly because of input/driver or power supply sections, particularly if they have regulated sections.
Please consider that many times the amplifiers are operating "without" output tubes - when the B+ fuse blows. The amplifiers must be prepared for this condition.
As the cj's have a B+ fuse, I burned in the Teflon capacitors with the output tubes in place without fuse - no plate current, no tube wear! ARC's do not have fuses, I had to take the output tubes out.
BTW, some Jadis amplifiers have a standy/power switch - if it is the case just burn-in the coupling capacitors in standby!
It would be great if they had explained what damage and why. Can you elucidate us?
I did not invent this idea, experienced people from DIY forums also use it and never reported any problem. The only problem I can think about is with poorly designed amplifiers that have power capacitors with unsafe voltage ratings - not the type of amplifiers I want to own. A power amplifier should not be seriously damaged if it has a fault in a power tube.
BTW Jadis power amplifiers have very simple circuits and high quality components.
The best I know about is Atma-sphere - Ralph Karsten used to pull the tubes of the amplifier while is was playing!
I have heard a Jadis with EL 34’s in the past. If it wasn’t for the fact that the new models utilize the KT150’s, I probably would have gone for the model with EL34’s. However, IMO, the new KT150’s are far more wide band and resolving than the older EL’s. Biggest difference to me, and this was very quickly evident, was the major improvement at both ends of the frequency spectrum with the newer KT 150’s. I have not heard a Jadis amp with KT120’s, so cannot comment; except to say that I suspect it would probably be a step up over EL34’s also.
I did say I had the JA 100 and NAT Magma at the same time at home on the Verity. You cannot really make out anything from compare notes. They are different sounds
