Indeed it now is on GG2, not GG1. S-Amanero is like 3 weeks old at most.Yes, I plan to.
I will check, but it should be part of the standard configuration.
Thanks. I’ll check the price of RK recti. I guess it should be similar to the Takatsuki one.AL says Tak is better than Kr5u4g...but RK is better than basic kron 5u4g.
Thanks. I’ll check the price of RK recti. I guess it should similar to the Takatsuki one.
It's much cheaper. Khonfused too had both the older KR and the Tak, and he too said while there were differences his preferences weren't strong either way.
Hence my point. Output valves make much more difference, including in Al's system. He has many rectis and many output valves but I can't afford all that so I will have to make choice.
Al has 'em all, except new RKs. LoL
Recti pecking order for most tubes in his system is:
WE274b/Tak 274b
KR5u4g
Mazda 5r4gy
all the rest
For his EML mesh 2a3:
Shuaguang 274b
Mazda/WE
Tak
all the rest.
Shakti
What tubes do you have in your stash? Ever tried PSVANE UK Design 300B? They are the best bargain out there in 300b land!
Did you get the new RK Kron recti? what about the RK 300b?
Sorry Ked, but I said the Psvane UK design. Different beast to ANY other Psvane...a word to the wise...Psvane 300s are really not up to the level, sorry. That said Shakti went through all the main tubes when had his GG1. I guess he should try the new ones now and he doesn't seem restricted by budgets.
Shakti I have the special EML 45s, PX25s and 242s. I can get them over after June if you don't manage to source them before.
Today I received my new Lampizator Golden Gate Gen II in single ended, Volume version.
As I like 300b tubes, I start with Psvane 300b black treasury out of my tube stock, the recti is a Kron 5u4g, Lampi edition.
Other tubes will be checked soon, after my final speakers are installed (hORNS Universum are on the way)
My GGII SET (built date 12.2017) is fitted with the small Triode heater tubes. I decided for the new Volume/Pre option, as my Koda Preamp has no remote.
Listening to digital let me skip very often, so I need a remote, many CDs have different levels, so I need to adjust the Volume too often ....
my first impression is very good, unfortunately my GGI is sold since a time, so I have no direct comparison.
