Yes, I mean the 85 watt Absolare 85 Push-Pull amplifier.
Why was the Absolare SET model not your cup of tea?
I have heard Absolare twice on Rockport speakers at shows and, from what I could tell, I liked very much the combination.
I thought the Rockport were under driven. Nothing against the amps, just the matching of the amps to the speakers, plus it is a show so can't say much.
a year ago I was hot on getting tube amplification and briefly looked closely at Jadis, likely the JA80 Mk2. . . .
Your Honor, I am recalling this witness -- Mike Lavigne please return to the stand!
You have testified previously, Mr. Lavigne, that you like the crystalline transparency of OTL amplifiers. So, Mr. Lavigne, is it your testimony before this court that after years with the transparent darTZeel 458 mono amps, when you had a hankering 5for tubes you considered the transformer-coupled JA80, but not the incredibly transparent Atma-Sphere OTL? May I remind you, sir, that you are under oath!
Please explain this to the jury . . .
You have testified previously, Mr. Lavigne, that you like the crystalline transparency of OTL amplifiers. So, Mr. Lavigne, is it your testimony before this court that after years with the transparent darTZeel 458 mono amps, when you had a hankering for tubes you considered the transformer-coupled JA80, but not the incredibly transparent Atma-Sphere OTL? May I remind you, sir, that you are under oath!
Hello,
I own a Jadis JA200 MKII for about a year now in full Jadis system.
Before this amp I had JA80 Anniversary version and DA88. I have an experience in few other amplifiers from Jadis offer.
My JA200 MKII has some modification make in the factory at my request. The most important is SCR FEP Supersound Teflon linking capacitors. This is a technology from Jadis 25th Anniversary set and has a great contribution to fast and dynamic sound of their new amplifiers.
I can highly recommend a JA200MKII version. This amp is a huge improvement in sound compared to older JA200 on KT120 tubes.
If you have any questions please ask.
This is very interesting. Thank you for posting!
What other options or component upgrades are available?
Hello,
Wellcome to WBF - it is great to have the owner of a current Jadis MKII wanting to share technical details. The best part of the news is that these capacitors are available for owners of MK I versions.
Are you using them with KT150's? I a am currently burning-in 16 KT150's in a pair of conrad johnson LP275s and they seem now much more agile and with more bass slam and definition.
Teflon capacitors were used first time in JA80 25th Anniversary model. I went from these amps so I ordered these caps as a modification. In standard amps Teflon caps are not used.
In my opinion Teflon linking caps helps the Jadis amplifiers to get even better transparency and dynamics. My version of JA200MKII is rocket fast. I like orchestral music and believe me that Mahler or Wagner music truly comes to life and can be earth shaking now.
Yes, I use JA200 with KT150 that were standard tubes supplied with my amplifiers.
These tubes are fast, detailed and dynamics far from Jadis old rounded and overly sweet school but still extremely musical and involving.
MKII models have new power supply transformers as well as new output transformers. For JA80 models layout of the tubes is changed to ensure better air flow around KT150 tubes that runs very hot. I am not sure if upgrade from JA80 to JA80MKII is possible or advised as in standard tube layout the amps may run too hot.
I do not know C-J gear well but have heard their Art preamp and Premier 8 mono blocks some time ago and these were one of the best gear I have ever heard these time.
Jason Serinus reviewed the JA200s in this month's Stereophile...funny, his Pass XA amps ran hotter that 10-tube monoblocks.
was not too kind to them either. liked the tonal and textural beauty of some of what they did, but found them wanting in top end openness and sparkle and that the bass was lightweight and lacked definition. one guy's opinion.
in some ways classic tube sound (although there are a few tube amps which can touch most of the bases better than apparently these did) verses better solid state and certainly preferences were involved.
I couldn't help to think by reading that he's running them on the wrong speaker...especially after reading the measurements. I also think as a reviewer he needs to use a proper preamp.
His Jadis comments at Axpona with Vivid speakers had no issues with bass and said the highs were "glorious." Go figure.
