Ethernet cable
Jeffy
479
174
348
Orchard Lake, MI
Can anyone recommend a network or cat 5 cable to go between the server and my DAC. I am willing to spend money but not 1000,s of dollars.
Kingsrule
1,444
704
1,430
The WireWorld are really good. Red, can't remember exact name.
kennyb123
858
806
1,155
Kirkland, WA
Yes the Wireworld Starlight is really good. Their lesser priced Chroma is actually very good value. It easily beat a long run of Audioquest Cinnamon.
I use a 8m run of Chroma between my wall jack and a Thunderbolt Ethernet adapter connected to my Mac Mini - and then a 1m run of Starlight between the built in Ethernet adapter on the Mac Mini and a Sonore microRendu. (A bridged connection sounds better).
Sablon Audio
Industry Expert, VIP Donor
May 22, 2015
1,619
1,490
553
Not sure of the length you need, however I would recommend you look to a higher specification cable since they have a far greater bandwidth courtesy of the lower noise conferred by more sophisticated shielding (the data pair wires are additionally individually shielded). They also use larger conductors so you will experience lower resistance / voltage drop.
marslo
953
674
605
64
Poland
I use jcat lan cable, it makes a difference compared to generic cable but don' t ask me why, I don' know:)
Probably because of less RMI / EMI trasmission to the server.
http://jplay.eu/jcat/
treitz3
Super Moderator
Staff member
Dec 25, 2011
5,480
1,009
1,320
Hi Jeffy and good afternoon to you. Please offer us feedback on how it sounds. I am in the market for one....a 75 footer. Thanks.
Tom
Tecknik1
50
3
140
HCM VietNam
I have been using ethernet for over a year now and have tried WW Starlight, AQ Vodka, Diamond and most recently the Revelation Audio Cat 8 just for fun. WW Starlight being the cheapest of the group with he Diamond and Revelation Audio about the same price. I tried all of these cables at different points in my ethernet based system starting at the Router to Aqvox Switch, Switch to FMC , FMC to Server, Server to Dac. Its a close call between the AQ Diamond and Revelations Audio new Cat 8. ( I know about the bad rep Revelations Audio had for years ) but looking at the cable and literature whats it hurt to try but all give the nod to Rev. Audio over the Diamond due to quieter back grounds and resolution. AQ Vodka has the same attributes over the WW Starlight. When I purchased the WW the Platinum version wasn't released yet and I well try it someday.
treitz3
Super Moderator
Staff member
Dec 25, 2011
5,480
1,009
1,320
treitz3
Super Moderator
Staff member
Dec 25, 2011
5,480
1,009
1,320
Hmmm, not personally a big fan of the end result as to what hits these ears with OC. I might reconsider where the modem is located and get a shorter run.
Thanks Bob.
Tom
kennyb123
858
806
1,155
Kirkland, WA
I was able to compare the WW Platimun to the WW Starlight. The Platinum was more transparent and offered more spatial coherence. I found it difficult at the time to justify the price difference though. Definitely a case of diminishing returns. I do think though that it's worth auditioning the Platinum if one has a really optimized setup.
jfrech
2,157
753
1,160
Austin
plissken
29
1
16
I terminated 315 feet of CAT5e and compared to a WW and Nordost (12 and 3 foot) and no difference with a Cary Audio DMS-500 even when I ran the 315 generic CAT5e under a running microwave for a source of noise.
