audio research Ref 6
XV-1
3,620
2,629
1,860
Sydney
James
you ordered one yet? :)
analog brother
233
3
starting to like it now...but no, i must not!!!!
i am very happily be-wedded to the se.
T.Barry
1
Introducing McIntosh Group
We are proud to introduce McIntosh Group, formerly Fine Sounds Group, and its new website www.mcintoshgroup.com. McIntosh Group is the parent company of six luxury audio brands – Audio Research, McIntosh, Pryma, Sonus faber, Sumiko Subwoofers and Wadia – an unparalleled assemblage of performance audio brands each with its own unique history, distinctiveness and reverence from their longtime customers. The website details our vision and philosophy for McIntosh Group in addition to providing a brief overview of each brand.
We continue to be excited about what the future holds for the audio industry and look forward to growing our ongoing relationship with you.
All the best,
McIntosh Group
rau
588
657
345
Wisconsin
I dropped the ball today and ordered a Ref 6 my first Audio Research product. I should see it in time
for the weekend
Cascais
257
2
150
for the weekend
Congratulations on your choice for your new preamp. I have both the Ref 5SE and the much more expensive Dartzeel NHB-18NS and prefer the ARC, so you should be very happy with your new Ref 6. But be prepared for >400 hours of break-in blues. What preamp is the ARC replacing?
rau
588
657
345
Wisconsin
I was wondering if anyone compared the SE to the Balance on the Ref 6 , I am using a Totaldac Twelve and it is SE . I can purchase some transformers from Totaldac that will convert the SE to Bal but then I will also need to purchase another pair of cables and I'm wondering if the cost vs performance is there .
dafos
306
I've been using ARC reference preamps for years and unless the source has balanced outputs, there's no sonic advantage to converting a single ended output to balanced. Using a transformer to convert a single ended signal to balanced just adds another component to the signal path and technically more damage and or loss to the purity of the signal.
rau
588
657
345
Wisconsin
Even if the end result is a complete true balanced system from input to output
Audio Research stated " recommend balanced connections input -to-output for best dynamics and resolution "
4,702
The SE inputs of ARC tube preamplifiers are excellent sounding - unless you want to isolate grounds I do not see any advantage in adding a balancing transformer. But sometimes adding a transformer can improve (or degrade, sorry) the sound quality, particularly if the transformer has a transformation ratio different from 1:1 . In doubt, you should ask the DAC manufacturer.
rau
588
657
345
Wisconsin
I gave it some thought and what you said makes sense Thanks
Robert < NxLT > Slowinski
33
6
240
Poland
www.nxlt.eu
I have purchased new Audiodharma Cable Cocker. In the meantime I`m asking myself if the result will blown me away with the speaker-Capacitor burn-in , maybe I should also burn the capacitors of my new Preamplifier the Audio Research Reference 6 ? Thake them out and burn properly on the Cable Cocker ;-) Just a thought, the unit sounds great imho. I like soldering and make some test ;-) Does anybody know somebody done that ?
dafos
306
Unsolder and remove the gold coupling capacitors of a brand new, beautifully built great sounding preamp?? Unless your goal is to void the warranty.
rau
588
657
345
Wisconsin
wow that's a bit extreme is it not , I didn't even want to change my IEC to a 15 amp
4,702
This is crazy - if you want to burn-in them just get some wires with alligator clips. If the preamplier is turned - off, the capacitors are in a medium -impedance state as the cathode resistor is around 10 kohm and the other wire of the capacitor is grounded by the mute relay.
33
6
240
Poland
www.nxlt.eu
Thanks microstrip. That would be the best solution. Are you 100% sure that I will not harm my beloved preamplifier ? I was also thinking about this, and even take out the valves out to be sure I don't damage anything.. Can another forum member approve this approach?
rau
588
657
345
Wisconsin
IMG_1321.JPG 75 hours on the Ref 6 and can't stop listening " wow " sounded best tonight since out of the box
