Thanks jazzhead.
Yes I think it is very likely that they will need some burn/settling in time.
Are you using them on terminals for the earth leads for sources? My thinking was to use them in that way and on the Poseidon negative amplifier speaker terminals,
Wow! That looks impressive.
Guillaume
Impressive indeed Jazzhead. Were you listening to analog or digital? What music was it? I am asking to rule out micro climatic changes such as temperature or humidity, which can have a similar effect to what you have experienced. Olof's new toy could give more stability to a joint. Do you have any idea what and why could have made for the startling change in the sound of the piano which you had experienced?
congrats Jazzhead!
Cheers LL , trust the fine tuning is coming along well .
steady, steady...have done a respectable job of getting low-bass under control and getting the main equipment properly isolated/rfi/emi shielded. In about 2 weeks, with everything settled in, we will recalibrate the main speakers to really fine tune based on my listening notes. We may also address a bit of the room via treatments.
Thanks Jazzhead! Reallly very interesting. Your report tempts me to try it myself. I have a Troy on digital and on the Kondo, Entreqs on the Lamm frontend and lamm phono as well as on all my amps. The result was first nothing, but after a day or two a greater naturalness of the sound as before, the ability to listen deeper into the music , a liquidity that was not there before. These effects seemed to deepen even
more in the first two weeks and have by now become the new normal. In fact, I am so happy with the way that my rig sounds these days, that basically I do not want to experiment at the moment. Should I however give in to temptation, what and where do you suggest should I apply Olofs new toy?
Hi there cuntigh.
You need to check out the Entreq website.
You need separate ground boxes or a Poseidon to connect the speakers. The earth cables connect to the amps negative speaker terminals and the speaker terminals, but you can't use an Olympus or Silver Tellus.
Must use separate ground boxes or the Poseidon which is three separated Olympus Minis.
Thank you Barry,
I haven't even conected my amps so I asked myself what is more efficient : connecting amps or speakers first ? If I think about, I can't imagine to have so many Entreq boxes (1 Olympus Tellus +2 minis for the amps and again 2 for the speakers...).
When I had the Silver Tellus and Atlantis in my furniture every people that came home asked me why I put my wine in that strange place ....
Cuntigh
Hello everybody,
I now have an Olympus Tellus wth many inputs. I'd like to know if someone already tried to connect the speakers to an Entreq box and if yes on which loudspeaker input ? Also do you need, as for connecting the amps, connect one speaker to a dedicated box ?
If someone tried that what is the sonic benefit if ever there is one ?
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
